[ICEM] Importing Points for Airfoils
Like Tree1Likes
  • 1 Post By FJSJ
Old   March 22, 2013, 13:45
Default Importing Points for Airfoils
leo_NM is on a distinguished road
Good Afternoon
I'm Trying to import the selig 1223 coodenates on ICEM like one tutorial I found on youtube but I'm having problems with it.
http://www.youtube.com/watch?v=tYrbScUH9RE
I counted the lines (with xcel ofcourse) and wrote this number and the number of curves like the tutorial said but....
When I select the file and press apply anything happens. I'm uploading the image of the two selig files, one is the original and the other is the one I modified following the tutorial instructions.
What's the correct layout of text to import points on icem CFD ? Is (*).dat a good format ?
thanks
leo_NM is offline   Reply With Quote
Old   March 25, 2013, 07:29
Javi
FJSJ is on a distinguished road
If you followed the video tutorial is easy to do:
1) Number of points per curve
2) How many curves are
3) Points of curves. Starting with the leading edge.
If you are using a. txt to import the points, here I give you a file that you serve as an example.
File Type: txt NACA Sectrion 63-206.txt (966 Bytes, 696 views)
jzapatau likes this.
FJSJ is offline   Reply With Quote
Old   March 25, 2013, 08:08
Thank you !!
It worked !!!
Old   March 29, 2013, 11:46
Default Leading edge radius?
Sheng
micro11sl is on a distinguished road
Using your coordinate, I've got a sharp leading edge which is not smoothed--see the attachment. Any ideas? Will you suggest more dense data points?
Sheng
micro11sl is offline   Reply With Quote
Old   April 9, 2013, 03:06
Javi
sorry for answering so late. I have always used this method and it works. Maybe it's because you do not have much points in that area (leading edge) or a graphic resolution problem.Try it with other profil with more points.
Old   April 9, 2013, 04:21
Sheng
So this is what I am worried. Because you separate the aerofoil to two curves joined together at the leading edge and trailing edge, how to ensure the curves are tangential to each other at the leading edge?
Regards,
Sheng
Old   April 10, 2013, 03:43
Javi
take a look on Simonīs video:
Just only 35 seconds, from 0:15 to 0:50. I always put the pressure area (in this case curve) and suction area, hence, 2 curves. About tangent point, always begin the curves from 0,0,0 and end them at 1,0,0 (x,y,z).
Old   April 10, 2013, 05:56
Sheng
Hi FJSJ,
Thanks for your reply. I've gone through the video again. I tends to think more points near the leading edge will be better. So I grab a coordinate file of a Clark Y aerofoil and import it into ICEM. Please see the attached picture. The leading edge is of good quality as no non-tangent places can be observed.
So the key point is to keep sufficient coordinate points near the leading edge.
Regards,
Sheng
Old   April 10, 2013, 06:23
Javi
Good one. As I said you, in this area must be some points more than you put in the first image attached. There were only 3 points exactly near to the leading edge.
I'm glad it's been resolved!
Old   April 10, 2013, 14:16
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Sufficient points are necessary and more important is to make the airfoil in four sections :
Leading edge
Suction side
Pressure side and
trailing edge.
Far is offline   Reply With Quote
Old   April 23, 2013, 18:02
Sheng
Leading edge
Suction side
Pressure side and
trailing edge.
In the four segments you mentioned, how large or how long should the leading edge be? I guess short?
If using the "leading edge" zone, I am worried because the post processing may be more complicated. When not using the "leading edge" zone, after solution, it is convenient to plot pressure coefficients or skin friction on aerofoil surface because I can simply select the "upper" and "lower" surface as the wall zone. If a "leading edge" zone is in presence, I probably have to export data on all wall zones with coordinate X Y, and then plot in other programs, because it is not necessary to say which part on the plot is on the leading edge in the legend (the upper and lower division is already sufficient).
Sheng
Old   June 15, 2017, 07:44
Default RAE2822 coordinates on ICEM 15.0
  #12
Prasetyo Edi
pedi_cfdonline is on a distinguished road
Hay all,
I'm Trying to import the RAE2822 coordinates on ICEM 15.0 like one tutorial I found on youtube but I'm having problems with it.
Anyone, please help
many thanks : P Edi
pedi_cfdonline is offline   Reply With Quote
Old   June 15, 2017, 10:03
Javi
Hi Prasetyo,
What sort of problem do you have? I have realized you specified your curves have 70 points but actually have 65. At the same time, I got this airfoil shape...
Old   June 15, 2017, 10:59
  #14
Prasetyo Edi
ya you right, thanks
[snappyHexMesh] .STL: non-closed manifold surface giulio.topazio OpenFOAM Meshing & Mesh Conversion 32 November 25, 2016 03:15
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
Importing Points in Design Modeler danh ANSYS Meshing & Geometry 5 March 30, 2015 10:45
[DesignModeler] DM's JScript: FPoint()'s GetPoint(i) function picks points backwards? ANT ANSYS Meshing & Geometry 2 July 23, 2012 15:25
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
