[ICEM] Aspect Ratio is too high. ICEM
Like Tree8Likes
  • 5 Post By Far
  • 1 Post By Ananthakrishnan
  • 1 Post By Dorasemon
Old   April 27, 2013, 23:06
Default Aspect Ratio is too high. ICEM
Emon P
Dorasemon is on a distinguished road
Hi, everyone.
I want to know how to control the aspect ratio if the height of boundary layers is less than 1% of the global sizes.
I am simulating ventilation in office room and there are some energy sources in my case. I should ensure the y+<5 so the aspect ratio is very easy to be higher than 100. Especially in the domain far away from the boundary, I don't know whether this problem will cause wrong results in fluent.
By the way, I use blocking method.
Thank you in advanced for any information.
Dorasemon is offline   Reply With Quote
Old   April 28, 2013, 02:19
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
is it a 2d problem? AR of 100 is not too high. However to enhance accuracy use double precision solver with high aspect ratios.
Far is offline   Reply With Quote
Old   April 28, 2013, 07:56
Emon P
Thank you very much, I will try double precision.
It is a 3d problem. In my case, the temperature is about 1℃ lower than experiment . I can't find the reason so I thought the problem may be aspect ratio.
Old   April 28, 2013, 08:17
Far
Sijal
For 3d problem you can have AR upto 1000 or even higher.
Mesh is the problem but not always
Old   April 28, 2013, 08:40
Emon P
Thanks.
I will try use other turbulence models or refine the mesh.
Old   April 28, 2013, 11:15
Ananthakrishnan.A.S
Ananthakrishnan is on a distinguished road
Send a message via Skype™ to Ananthakrishnan
Just in case if you have not discovered this idea. Keep a uniform node distribution in the far field boundary. This will help reducing the aspect ratio as well. If not you might end up having reversed flow at the outlet in fluent.
hope this idea is relevant to you!!
AlexRonto likes this.
Ananthakrishnan is offline   Reply With Quote
Old   April 28, 2013, 11:31
Far
Sijal
Ananthakrishnan : Very relevant hint. I agree too
Old   April 29, 2013, 09:39
Emon P
Originally Posted by Ananthakrishnan View Post
Ananthakrishnan:
Thanks. In my case, their are some computers(rectangular box, use temperature as boundary condition in fluent) on a table(thickness=0) in the office.
I split the block and set the edge params to control the spacing and ratio, this cause the aspect ratio very high. I don't know how to keep uniform node distribution in the far field boundary and control the spacing and ratio at the same time.
Could you tell me how to mesh the boundary layers near the computer surfaces and table?
Thank you very much.
Old   April 29, 2013, 09:57
Far
Sijal
Instead of using copy to all parallel edges, set spacing parameters individually.
Give fine spacing/ratio on the wall surfaces (computers etc) and define uniform spacing in the farfield.
Old   April 29, 2013, 10:03
Emon P
Far:
If set spacing parameters individually, would the grid orthogonality be another problem?
Old   April 29, 2013, 11:29
Ananthakrishnan.A.S
Theoritically it can cause some problems. Just check the pre mesh orthogonal quality. If its too bad then you might have to change your blocking strategy a little bit at those places..If not you can go ahead.
Generally it does not create such big problems. Go ahead and try it out!! because without that there are very high probabilities of reverse flow
allanZHONG likes this.
Old   April 29, 2013, 11:49
Emon P
After trail and error, I get better result using hex-core method to generate mesh and Launder-Sharma model instead of k-e RNG turbulence model, even though mesh quality is very low(I don't know how to refine it, so I let it be).
Next step, I will try what you and Far suggested.
Kvothe332 likes this.
Old   April 29, 2013, 11:59
Emon P
Far:
What you said is absolutely right!
When I change RNG k-e to Launder-Sharma model, I get better result. And I will try refine the mesh to find whether bether mesh can get good result or not.
I really appreciate you helping me.
aspect ratio of boundary layer elements in COMSOL TryMyBest Mesh Generation & Pre-Processing 0 March 11, 2013 06:53
[ANSYS Meshing] High aspect ratio Roby_1986 ANSYS Meshing & Geometry 0 February 22, 2013 05:34
Automobile aero ground boundary layer OR simpleFoam/GAMG and high aspect ratio cells kyle OpenFOAM Running, Solving & CFD 4 January 4, 2011 11:17
does aspect ratio affect analysis mahesh Main CFD Forum 2 October 10, 2005 09:12
Help Needed: High aspect ratio Michelle FLUENT 0 January 24, 2003 03:15
