[ICEM] Blocking Strategy And Quality
Like Tree1Likes
  • 1 Post By diamondx
Old   April 29, 2013, 04:55
Default Blocking Strategy And Quality
Javi
FJSJ is on a distinguished road
Hi guys,
I want to ask you for a doubt about blocks and quality. In the first three pictures you can see the domain, mesh quality and some blocks. Then in the 3 last, you can see a very similar example (the same as before but... with the tip). But as you can see the quality is very bad. So.. my question is..is it a normal behaviour? I mean, Iīve placed all the vertices in the same location that example before where I got a good quality . I think that, maybe, this can be for the tip blocking that is new in the second example and can influence in them but Iīm not sure.
FJSJ is offline   Reply With Quote
Old   April 29, 2013, 04:56
Javi
Here the bad elements in the second example
Old   April 29, 2013, 05:03
AB
BrolY will become famous soon enough
Those are not bad elements, they are inverted elements ! Something is wrong with your blocking.
Share your *.tin and *.blk files so we can have a look.
BrolY is offline   Reply With Quote
Old   April 29, 2013, 05:06
Javi
Inverted elements?? I have exactly the same blocking in the first example and I donīt have inverted elements. That is my question. I canīt understand why in one yes and other not.
Old   April 29, 2013, 05:25
AB
But your geometry is not the same than in the first example ?
That's why there are inverted elements !
Old   April 29, 2013, 05:44
Javi
I have the same geometry and blocking in both examples. Thatīs the weird...
Old   April 29, 2013, 05:47
AB
Originally Posted by FJSJ View Post
Hi guys,
You said "the same as before but ... with the tip". Maybe your blocking doesn't cover that, and that's why it created inverted elements.
Can you share both projects ?
Old   April 29, 2013, 06:05
Javi
Maybe I explained wrong. I said "the same as before.." but refered at the geometry plus the tip blade. But yes, the blocking in the second example covers the tip. Look at this pictures.
Old   April 29, 2013, 08:51
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
it should be a minor problem with your blocking , run scan mesh and scan planes for investigation
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 29, 2013, 11:21
Javi
Itīs possible that It can be because ICEM confused parts? As you can see, I have a color blade part in a part where doesnīt have to... Diamondx told me once again, I have to specify more precisely... Can be for this reason?
Old   April 29, 2013, 11:32
diamondx's Avatar
Ghazlani M. Ali
the problem is related to association, you have to re-do your associations
FJSJ likes this.
Regards,
Ali
Old   April 29, 2013, 16:57
Javi
Ok. Iīll do again the associations. Iīll post tomorrow the result.
Old   April 29, 2013, 17:02
Javi
However, the edge association picture of this examples is this. And I donīt see any wrong association. The problem is only in that area or.. can be in any of them?
Old   April 30, 2013, 03:09
Javi
I think Iīve just resolved the problem about inverted cells. Iīve disassociated from geometry the edges but It didnīt work. So.. I used "Associate Edge to Surface" tool and problem was resolved. Here the picture. Thank you guys for the answers!
Although I would like to know why in the first example that I showed you I didn't have to use this tool and only I used "edge to curve associate". How does this behavior depend?
Old   April 30, 2013, 11:21
Javi
I donīt know If I should create a new thread or not to ask for this topic... Iīve reduced highly bad elements but I have a bit of them. The problem is that bad elements are in a difficult area.. the tip. I got this approach few days ago. And now, I donīt know if I have to think in other approach or I can improve this one. Iīve seen Ralenīs approach but I decided to think in other because my domain is cylindrical. So... if anybody can provide some idea... this is welcome.
Thanks!
[ANSYS Meshing] Blocking and Meshing around a vane vortex generator Crank-Shaft ANSYS Meshing & Geometry 5 January 17, 2016 23:29
[ICEM] Blocking Strategy For a simple Box Tarantino ANSYS Meshing & Geometry 6 February 3, 2013 08:15
[ANSYS Meshing] Blocking and Meshing Strategy for an open flow domain over backward facing ramp Crank-Shaft ANSYS Meshing & Geometry 0 January 11, 2013 05:48
[ICEM] Tips for 3D tetra mesh quality for Fluent transient run. Rotary Engine Catthan ANSYS Meshing & Geometry 0 June 18, 2012 12:46
[ICEM] Blocking strategy BrolY ANSYS Meshing & Geometry 0 July 22, 2010 04:46
