May 23, 2013, 09:28 |
Blocking a triangular surface
Rep Power: 16 |
I'm blocking and meshing a domain depicted in the figure below. The two rectangles and the triangle with a fillet in the tip are not included in the fluid zone. My problem is that I haven't managed to create a satisfactory mesh for the domain near the triangle surface, there are some non-orthogonal faces.
I've attached pictures of my current blocking and mesh. I'm sure that this is an easy task but I just can't figure it out. |
May 23, 2013, 10:21 |
Javi
Rep Power: 16 |
Can you share your .tin file?
May 23, 2013, 10:30 |
Philipp
Rep Power: 26 |
Your mesh (3rd picture) looks bad... the triangle looks like a pyramid, did you assign all edges to the curves? Some of the quads are "cutted" at the edge of the triangle. Anyway: If I recall correctly, user "far" showed a good blocking for triangles in some thread, maybe that helps: triangle meshing.png
The skeleton ran out of shampoo in the shower. |
May 23, 2013, 14:35 |
Rep Power: 16 |
Thanks for replys. RodriguezFatz: yes, I did assign them. I also found this video a few days ago http://www.youtube.com/watch?v=92vScop7b8Q but didn't manage to get things working.
Anyway, I will be out of office until Monday but will report my results after giving it another try. |
May 23, 2013, 15:12 |
Philipp
Rep Power: 26 |
But what about the triangular faces of the middle body? He needs to mesh the front and back of it.
@esgee: Did you cut the middle body, or why does the screenshot of the grid look so strange?
May 24, 2013, 02:01 |
Philipp
Rep Power: 26 |
Why not like this?
May 24, 2013, 02:17 |
#10 |
Philipp
Rep Power: 26 |
Yes the top hexas will be crap in my blocking...
May 24, 2013, 02:24 |
#11 |
May 24, 2013, 03:19 |
#12 |
Philipp
Rep Power: 26 |
Doesn't that depend strongly on the way the flow takes, i.e. on the inlet and outlet positions?
May 24, 2013, 03:23 |
#13 |
Javi
Rep Power: 16 |
Hi guys,
Iīve done a quickly blocking. I think this blocking can be improve better, maybe this block is similar to Philippīs idea. Anyway, if anybody want to try I give you the geom here! https://www.dropbox.com/s/heej79l4v9...riangleBox.rar |
May 25, 2013, 17:21 |
#14 |
Javi
Rep Power: 16 |
Far, would be so kind draw a simple picture with the blocking approach? I mean, like Philipp did. Itīs only to see the blocking shapes arround the round tip. Thank you!
May 27, 2013, 07:33 |
#15 |
Rep Power: 16 |
Hello again. I tried to apply same approach as FJSJ but my grid is still bad.
e: I finally managed to solve it. Thanks for your kind effort. Last edited by esgee; May 28, 2013 at 07:54. |
May 27, 2013, 08:23 |
#16 |
Javi
Rep Power: 16 |
well, itīs not my approach, in any way, it would be Philippīs approach. Anyway, this is not the best blocking. Farīs idea is the best, at least, I think so. But I would see some picture with blocking edge, like Philipp did.
May 28, 2013, 15:35 |
#17 | |
Min quality 0.66 and min angle 44. Files are attached. Here is the blocking: PS: Dedicated to Simon |
May 29, 2013, 02:53 |
#18 |
Javi
Rep Power: 16 |
Thanks you for explaining the blocking with the O-grid!
May 31, 2014, 03:52 |
3D Wing
#20 |
Germany
Rep Power: 12 |
Hi Far
I have to mesh the fluid around this 3d Wing. As you see i have a complex 3D Wing and i have to mesh it, the problem is the vertical part of the wing and as you see here i have splitted it to 3 parts. To have a good mesh i need to split the left and right Blocks to Blocks with triangle Surfaces to fit with the parts of vertical Surface. Could you please give me an idea to do that or mesh it? Thanks |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
[General] extract Ids of point subset from a give triangular surface | nacaairfoil | ParaView | 1 | September 18, 2012 12:19 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
[ICEM] Automatic mesh generation script surface intersection problem | stuart23 | ANSYS Meshing & Geometry | 0 | May 13, 2011 01:10 |
Normal - Helical Surface | m. malik | Main CFD Forum | 3 | February 3, 2006 12:56 |
