[DesignModeler] how to add a node?
Old   May 26, 2013, 23:16
Default how to add a node?
jiaqi wang
itsqi7 is on a distinguished road
Hi there,
I hope to use Vertex sizing control in my mesh to refine certain region. But I don't know how to add a node into the model. Can anyone told me how to do that? My model is created in Creo and used to play a CFX simulation.
Thanks,
itsqi7
itsqi7 is offline   Reply With Quote
Old   May 27, 2013, 02:08
Josef Runsten
jrunsten will become famous soon enough
Send a message via MSN to jrunsten
If it's refinement you are looking for, then you can use "sphere of influence" for body sizing:
All you need is to define a coordinate system at your point.
jrunsten is offline   Reply With Quote
Old   May 27, 2013, 03:51
jiaqi wang
Thanks a lot. I found it in the Mesh. I tried to add plane in designmodeler but it didn't work. So now it works.
mpirun, best parameters pablodecastillo Hardware 18 November 10, 2016 12:36
[ICEM] Expanding and constant node distribution siw ANSYS Meshing & Geometry 2 February 4, 2013 13:47
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 UDS_rambler FLUENT 2 November 22, 2011 09:46
License server not visible from master node Charles FLUENT 0 October 30, 2007 17:48
Full Fluent license required for the master node? Paul FLUENT 1 September 1, 2006 04:26
