[ICEM] Multiple edges problem when merging hexa/tetra mesh |
May 30, 2013, 20:26 |
Andrew Kang
Hi, I've been learning how to merge tetra/hexa mesh together
and now I know how to do it for an example in the tutorial. I'm trying another simple but a bit different example trying to merge tetra/hexa mesh. As you can see from file below, I'm merging different sized boxes each with tetra and hexa meshes, and followed the procedure given in the tutorial. Here's project file link right before merging the volumes. http://www.2shared.com/file/JC9xFOfh/test.html At frist, it seems to be working, but when I check the mesh, I found 'multiple edges around the interface and I want to eliminate all the multiple edges. If any of you know how to tackle this problem, please let me know.. I'll really appreciate it.. |
May 30, 2013, 22:20 |
#2 | |
Ghazlani M. Ali
Rep Power: 29 |
an expert once said:
May 30, 2013, 22:56 |
I've read that already.
Andrew Kang
Thanks!
I've figured out the solution to my problem. Last edited by earth07; May 31, 2013 at 01:32. |
May 31, 2013, 03:29 |
Javi
Hi guys,
If I want to do this "...or just delete the shells in the interface part before you export to the solver"... how can I do it? Is that I have not very clear.... Thank you guys! |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
[snappyHexMesh] snappyHexMesh aborting | Tobi | OpenFOAM Meshing & Mesh Conversion | 0 | November 10, 2010 03:23 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
