[ICEM] Error 2D mesh - Separate curves seen as one when associating |
June 11, 2013, 05:52 |
Bayard Morales
Hello there.
I have been dealing with the same problem over and over in ICEM 14.0, maybe you can help me. I am creating a simple 2D mesh, following the procedure below: 1) create points 2) create curves from points 3) create parts from curves 4) create planar 2D block 5) associate edges to curves 6) define pre-mesh params 7) convert to unstructured mesh 8) output to FLUENT What happens is when I read the mesh in FLUENT, the boundary conditions (related to the parts) can't be seen. Going back to ICEM, I noticed that when I check the Info of each part, the missing parts contains no elements - as if the was no edge association to them. I tried to redo the edge association to the curves and then I have found that when I try to select the a single curve (related to a part), I can only select all curves at once. The only solution I've found so far is to deleted all the geometry and build it again. Any idea? Am I doing something blatantly wrong? Cheers |
blocks, mesh |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Mesh | Mignard | FLUENT | 2 | March 22, 2000 05:12 |
unstructured vs. structured grids | Frank Muldoon | Main CFD Forum | 1 | January 5, 1999 10:09 |
