[ANSYS Meshing] Meshing Error For Triangular Channel |
June 23, 2013, 08:56 |
AJ Hunter
I have a fluid simulation problem where I have a triangular channel inside an aluminum cylinder (Basically like someone drilled a triangle all the way through a cylinder). When I go to create my inflation to make a boundary layer, I select the three faces of the triangle which runs for 15 cm (sides are 0.85 mm, 0.85 mm, 0.76 mm).
My inputs for the inflation are: Scoping Method: Geometry Selection Geometery: 1 Body Supressed: No Boundary Scoping Method: Geometry Selection Boundary: 3 Faces Inflation Option: Smooth Transition Transtion Ratio: 0.25 Maximum Layers: 15 Growth Rate: 1.2 Inflation Algorithm: Pre I get the following error: "Pre-inflation layer generation is stopped because of side face limitation, proximity collisions and quality." Afterward, the mesh shows no boundary at the face. I have tried messing with the parameters, but havent had any luck. |
error, inflation, mesh, triangle |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
[ANSYS Meshing] Micro channel waterblock meshing. | codenamew | ANSYS Meshing & Geometry | 0 | January 2, 2012 09:55 |
meshing triangular channel | mu | FLUENT | 3 | February 22, 2008 11:31 |
help with meshing trapezoidal channel | rosol | FLUENT | 0 | September 14, 2007 03:26 |
tetrahedral meshing in square channel | Aashutosh Magdum | FLUENT | 4 | May 28, 2005 20:27 |
