gambit mesh "T" tube
Old   June 25, 2013, 04:02
Default gambit mesh "T" tube
steven
steven1 is on a distinguished road
hello everyone,
i am a beginner of gambit. now i am trying to creat a mesh on a "T" form tube. do you have some ideas pr suggestions about how to seperate the different parts?
thank you
steven1 is offline   Reply With Quote
Old   June 25, 2013, 04:23
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
you are not enforce to decompose your domain, execpt if you want a full hexa mesh
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   June 25, 2013, 04:52
steven
i have used fluent to calculate, it showed that there were instability at the entrance of the small tube. so i have no choice to seperate the interval part to have a more precise part. but i always get a great number of mesh.
Old   June 25, 2013, 04:58
-mAx-'s Avatar
Maxime Perelli
post pictures, and explain your boundary conditions
Old   June 25, 2013, 05:14
steven
Hello , this is the tube that i use,.
The boundry conditions are : turbulence with a velocity of 5m/s inlet.
Flow rate weighting 0.5 ; 0.5
Old   June 25, 2013, 05:18
steven
i don't knoz how to add pictures, to i make a link here. thank you
https://www.dropbox.com/s/s1ufa02vv9oka4k/0625.docx
Old   June 25, 2013, 05:19
-mAx-'s Avatar
Maxime Perelli
I don't see pictures
What kind of BC did you use for outlet?
-mAx-'s Avatar
Maxime Perelli
you have to go in advanced mode
Old   June 25, 2013, 05:21
-mAx-'s Avatar
Maxime Perelli
please post picture with focus on your mesh, else we don't see anything.
Pleas post also picture of velocity and pressure distribution
Old   June 25, 2013, 05:48
steven
this is the document; https://www.dropbox.com/s/5oqvv81gvb...0question.docx
sorry for making you waiting so long, i am not used to the computer with the french keyboard that i use.
Old   June 25, 2013, 06:17
-mAx-'s Avatar
Maxime Perelli
ok can you display clother at the T junction, especially velocity distribution. Something sounds weird left to the T junction.
Regarding to the mesh, you seem to have splited your domain, right?
Can you also list all the surfaces with their BC, I see lots of surfaces
And finally when I see the the velocity distribution, I assume your inlet is the pipe with smaller diameter. But if it is exact, then the pressure distribution is wrong
Old   June 25, 2013, 07:05
steven
yes, you are right, i have splited the domaine.
the inlet is the left side of the larger pipe, the other side of it and the small pipe are the outlets. The diameter of the larger pipe is 20mm, that of the small one is 6 mm, and the lengh of all the three parts around the intersection is 500mm
https://www.dropbox.com/s/c7o9q4nrku...question1.docx
Old   June 25, 2013, 07:13
-mAx-'s Avatar
Maxime Perelli
can you provide me your dbs file from Gambit? (delete the mesh for reducing file size)
Old   June 25, 2013, 07:24
steven
https://www.dropbox.com/s/nsfn9id1k1...lageRe10-5.dbs
here it is, there are some changes, i didn't save that version.
Old   June 25, 2013, 07:48
-mAx-'s Avatar
Maxime Perelli
ok, seems to be ok, but you don't have any surfaces in the BC.
I assume you fixed the problem.
Other point: what are your dimensions m,mm,... ?
Old   June 25, 2013, 08:13
steven
the dimensions are mm. and in fact i am a beginer of fluent and gambit, i don't know which faces to add with BC
Old   June 25, 2013, 08:21
-mAx-'s Avatar
Maxime Perelli
ok, did you scaled your domain in fluent?
Gambit doesn t have any dimension.
Old   June 25, 2013, 08:36
steven
ok, i find that i am totally fool, i thought the dimension was set by default as mm. i just searched the user's guide, it's set as Meter. however, i didn't scale the dimension
Old   June 25, 2013, 08:42
-mAx-'s Avatar
Maxime Perelli
you have to scale your domain:
in your case, select mm, and then click on scale
If you have a diameter of 20, Fluent will understand 20m
If you scale it, Fluent will convert and undestand 20*1e-3 = 0.02m
Once it is done, do a check mesh, to be sure that your mesh is ok.
Then compute.
Old   June 25, 2013, 08:45
steven
OK, thank you very much. i think i have to rebuild the mesh as the skewness exceeded 0.98
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
[ICEM] Hexa-Dominant mesh for a bended tube dst ANSYS Meshing & Geometry 5 October 9, 2013 16:27
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
ICEM block mesh with a ball in a cylinder tube Li CFX 6 August 11, 2008 05:44
3-D Mesh Check in Gambit..... SHR FLUENT 4 March 25, 2003 03:10
