[GAMBIT] How to plot S pipe
Old   October 9, 2013, 13:49
Default How to plot S pipe
mariam.sara is on a distinguished road
Hi I need to plot S pipe as 3D geometry in Gambit with diameter 20 mm and has contraction at the middle of it (diameter after contraction is 15 mm) anybody can assist me with it please?
mariam
mariam.sara is offline   Reply With Quote
Old   October 10, 2013, 00:37
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
do you have a sketch of your geometry?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 10, 2013, 02:44
Hi max thanks for the respond I sent you approximate picture for the draw as 2D I want this plot as 3 D all dimensions and boundary conditions were shown please try to add it with meshing the pipe and send me text with the JOU file if possible?
mariam
Old   October 10, 2013, 03:07
-mAx-'s Avatar
Maxime Perelli
you do it, and I will help you
For upper and lower "loops" is the cross section constant? (20mm ř)
If yes you just need to use sweep function for generating volume.
Draw the "path" for your loop, create your surface section, and sweep.
Once it is done, you can recflect and move a copy of this volume for having the second "loop".
Place both volumes to their right place and you just need finally to create the restriction (ř15). Here your can use the revolve tool (2d sketch and revolve)
Once everything is ready you can unite all the volumes (or not if you need this decomposition for your mesh)
Old   October 10, 2013, 03:25
Yes both parts have 20 mm diameter thanks for the explaining and pictures I am not very expert with doing these processes in Gambit? however i will try and let you know I have lesson now will contact you later.
mariam
Old   October 10, 2013, 08:15
Hi I really failed to draw the path at your first image I draw the circle with radius 10 mm at yz plane then i tried to draw arc (with radius 10 mm too) but it not that shown in your picture may you tell me the steps of drawing it?
Old   October 10, 2013, 08:22
-mAx-'s Avatar
Maxime Perelli
I draw an arc because I wanted to do it quick.
Maybe you want somethink else than an arc...
It was just an example, anyway the procedure is the same whatever a path you choose: sweep your section along this path
The arc I designed is generated with https://www.sharcnet.ca/Software/Gam...dge_create_arc
method 3
Old   October 10, 2013, 08:28
I tried the third method but how much the radius of path? I select it same as circle radius (10 mm) but i think it wrong?
Old   October 10, 2013, 08:36
-mAx-'s Avatar
Maxime Perelli
pictures always help
Old   October 10, 2013, 08:53
Dear max i post you journal file please check is it correct? if it correct please tell me how to reflect the other part?
/ Journal File for GAMBIT 2.2.30, Database 2.2.14, ntx86 BH04110220
/ Identifier "default_id5284"
/ File opened for write Thu Oct 10 15:00:22 2013.
vertex create coordinates 0 0 0
edge create radius 40 startangle 0 endangle 180 center "vertex.1" xyplane arc
face create radius 10 xyplane circle
undo
/Undone to: face create radius 10 xyplane circle
face create radius 10 yzplane circle
undo
/Undone to: face create radius 10 yzplane circle
face create radius 10 zxplane circle
face move "face.1" offset 40 0 0
volume create rotate "face.1" onedge "edge.1" draft 0 extended
Old   October 10, 2013, 08:59
-mAx-'s Avatar
Maxime Perelli
Seems to be ok.
Gambit generates the volume?
Old   October 10, 2013, 09:06
Well how now i can reflect this volume to get the second part? i am really not understand too how to use revolve tool from 2D face as you mentioned? i do not have idea how to do it to draw the contraction part (i.e. with 15 mm diameter)?
Thanks a lot
Old   October 10, 2013, 09:12
-mAx-'s Avatar
Maxime Perelli
copy volume (option recflec) --> https://www.sharcnet.ca/Software/Gam..._volm_movecopy
For the contraction part you create a 2d-slice, and you revolve it around desired axis
https://www.sharcnet.ca/Software/Gam...#geom_volm_rev
Old   October 10, 2013, 09:31
I copy volume 1 and select reflect option with plane coordinates as below:
(0,0,0) -> (0,1,0)
it told me that the second volume created but i did not see it ?
Old   October 10, 2013, 09:33
-mAx-'s Avatar
Maxime Perelli
fit to window
https://www.sharcnet.ca/Software/Gam...304.htm#gc_fit
Old   October 10, 2013, 09:44
Thank you i did it but still not have any idea about the last part and what you mean with slice? may you tell me this step by step? sorry to bother you with my questions?
Old   October 11, 2013, 01:05
-mAx-'s Avatar
Maxime Perelli
Create your surface-section and rotate it
Old   October 11, 2013, 02:19
Hi max thanks again for the photos? If the diameter is 15 mm I aware the face height is (20/2 mm) but I wondered how much the length of the face in this case?
Old   October 11, 2013, 04:46
-mAx-'s Avatar
Maxime Perelli
If you don't know the details of your geometry, then I don't know too
Old   October 11, 2013, 13:45
Hi max an error happen when i tried to revolve the surface please can you check it i sent you the jou file below :
/ Identifier "ss"
/ File opened for write Fri Oct 11 19:52:15 2013.
identifier name "ss" new saveprevious
undo
undo
edge create straight "vertex.2" "vertex.3"
undo
/Undone to: edge create straight "vertex.2" "vertex.3"
edge delete "edge.1" lowertopology
volume reflect "volume.1" vector 0 1 0 origin 0 0 0
undo
/Undone to: volume reflect "volume.1" vector 0 1 0 origin 0 0 0
volume creflect "volume.1" multiple 1 vector 0 1 0 origin 0 0 0
volume move "volume.2" offset -40 0 0
undo
/Undone to: volume move "volume.2" offset -40 0 0
volume move "volume.2" offset -60 0 0
undo
/Undone to: volume move "volume.2" offset -60 0 0
volume move "volume.2" offset -80 -10 0
volume move "volume.2" offset 0 -5 0
vertex create coordinates -40 0 0
undo
/Undone to: vertex create coordinates -40 0 0
vertex create coordinates -20 0 0
undo
/Undone to: vertex create coordinates -20 0 0
vertex create coordinates -30 0 0
vertex create coordinates -30 -10 0
vertex create coordinates -40 -10 0
vertex create coordinates -17.5 -5 0
undo
/Undone to: vertex create coordinates -17.5 -5 0
vertex create coordinates -20 -5 0
undo
/Undone to: vertex create coordinates -20 -5 0
vertex create coordinates -25 -5 0
undo
/Undone to: vertex create coordinates -25 -5 0
vertex create coordinates -32.5 -5 0
edge create threepoints "vertex.8" "vertex.11" "vertex.9" arc
edge create straight "vertex.5" "vertex.8"
edge create straight "vertex.10" "vertex.5"
edge create straight "vertex.10" "vertex.9"
face create wireframe "edge.8" "edge.9" "edge.6" "edge.7" real
/ERROR occurred in the next command!
volume create revolve "face.7" dangle 360 vector 0 0 1 origin 0 0 0
[DesignModeler] DesignModeler Pipe within pipe shields ANSYS Meshing & Geometry 13 November 25, 2018 22:14
Double Walled Pipe Boundary dahvqaz FLUENT 2 December 5, 2012 10:14
plot Pressure drop in pipe monty_p20 FLUENT 0 November 17, 2011 17:18
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
