[GAMBIT] How to name inner domain in Gambit
Like Tree2Likes
  • 1 Post By -mAx-
  • 1 Post By -mAx-
Old   October 23, 2013, 10:54
Default How to name inner domain in Gambit
izna O'connor
izna is on a distinguished road
hello..
I have a large domain D.. I have one shape,S ( exotic shape) in my large domain.. I had drawn another small domain,X to surround my exotic shape so that i can mesh finest mesh around this and coarser elsewhere..
In gambit i had done X subtract S, then i retain both faces.. Next I did, D subtract X...
I had meshed my small Domain X finely and the bigger coarse.. everything was fine..
problem is my boundary condition.. what do I name the inner domain?
please help..
izna is offline   Reply With Quote
Old   October 24, 2013, 00:51
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
don't give any name of internal domain.
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   October 24, 2013, 02:04
izna O'connor
hello
If i do not name it.. In openFoam, it is taken as default Wall..
Please advice.
Old   October 24, 2013, 02:14
-mAx-'s Avatar
Maxime Perelli
You were talking about inner domain. So I understand a volume.
Then I assume you have wall between your default domain D and you refined domain X.
This is typical connectivity problem.
So you have to connect those surfaces
A picture is always welcomed
Old   October 24, 2013, 02:16
izna O'connor
hi its in 2D..
Old   October 24, 2013, 02:30
izna O'connor
inner shapes are wall..
Old   October 24, 2013, 08:13
-mAx-'s Avatar
Maxime Perelli
If you are working in 2d then bc are set on edges. (so you have to connect your edges)
I don't see anything on your picture
Old   October 24, 2013, 14:30
izna O'connor
when i do connec the edges i obtain the attached error..
I want wall only the buildings..
i have subtract the small square( domain) from the big domain.. and subtract the buildings from the small square domain..
Old   October 25, 2013, 00:34
-mAx-'s Avatar
Maxime Perelli
upload your dbs file in a share server, I'll check
Old   October 25, 2013, 03:40
-mAx-'s Avatar
Maxime Perelli
Ok as I thought: you didn't have any split.
So:
- go to face substract, and select face.2 as "face", then select all faces (except face .2 and face.1) in "substract faces"
-Now you have only 2 faces: face.2 (the one you generated with substract) and face.1, which you will use for the split
-go to face split, and selet face.2 in "face", and face.1 in "faces"
Now your domain is ready, you can mesh
Old   October 25, 2013, 03:47
izna O'connor
hi
you mean now on doing this, i can name my edges and not bother with the inner square?
also in
in my version of gambit, i have both as face.. firstone face and secondone also face.. whch one do i put as face2 and which one face1
Old   October 25, 2013, 04:02
-mAx-'s Avatar
Maxime Perelli
you just have to select the faces:
the first ("face") is the surface from which you want to generate a split.
The other ("faces") is the surface (or surfaces) you want to use for splitting
izna likes this.
Old   October 25, 2013, 04:05
izna O'connor
So for me
face2 is the first and face1 is the second..
Thankssss
Old   October 25, 2013, 04:17
-mAx-'s Avatar
Maxime Perelli
Also for me...
izna likes this.
Old   October 26, 2013, 16:05
izna O'connor
Hi max
Hwo do i close my volume?
when i do stitch volume, i got the error of
cannot create acis body. is this an open shell?
I have all the required face..
Old   October 28, 2013, 01:02
-mAx-'s Avatar
Maxime Perelli
you have to create each volume and then again the substract and split stuff (but with volume)
Old   October 28, 2013, 08:13
izna O'connor
hi max
thanks for a reply..
When i create volumes.. Ie stitch all my face together.. i obtain the Acis error..
Old   October 29, 2013, 01:56
-mAx-'s Avatar
Maxime Perelli
give me an example
gambit 2.2.30
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 22:43
Gambit help: Cube inside cube Jack Martinez FLUENT 13 August 11, 2010 06:29
Gambit -dev X11 doesn't work Ervin Amet FLUENT 0 October 28, 2007 08:33
rotating domain in rotating domain, different axis Robert Stringer CFX 3 December 4, 2006 07:04
