[ANSYS Meshing] Non-manifold error encountered while trying to generate enclosure
Old   December 29, 2013, 22:40
Default Non-manifold error encountered while trying to generate enclosure
R. W. Tan
PrinceTan is on a distinguished road
Good day ladies and gentlemen,
I am a final year student pursuing in Mechatronics Engineering in Malaysia. My final year project currently deals with automotive aerodynamics and my research involves comparison between a baseline model of a simplified car model and a model with airfoils
The problem as highlighted in the title occurred when I wanted to create an enclosure over the second model (the one with additional airfoils) where the enclosure operation would generate the error message.
Funny thing is the second model is the same as the first model only with extra airfoils attached at several locations. When I deleted all the airfoils, it is the same model as the baseline model, but when I tried the same enclosure again, the same error occurs. But the baseline model does not encounter the problem.
I have attached the .stp file of my geometry in this post for reference purposes. Thank you for your response in advance.
PrinceTan is offline   Reply With Quote
Old   January 21, 2014, 00:36
R. W. Tan
Just in case somebody else encountered the same problem as me, I have already solved the problem. Apparently, by converting to STEP format, the problem will remain, but if I convert the same model to IGES format, the problem is automatically solved.
aerodynamics, automotive, enclosure, error, non-manifold
Exhaust Manifold Transient Heat Transfer Simulation Jonny6001 STAR-CCM+ 9 February 22, 2017 13:24
[ANSYS Meshing] Meshing of a 3d Ringwing in a cylindrical enclosure Lukas_ZH ANSYS Meshing & Geometry 5 March 14, 2015 05:49
Exhaust Gas manifold simulation shrinath Siemens 6 September 5, 2013 16:26
[Other] Problematic Geometry- meshing with enclosure. lev1athan ANSYS Meshing & Geometry 2 February 24, 2012 16:24
need help with manifold analysis in fluent anil1886 FLUENT 0 August 29, 2009 10:29
