The P over the origin
Old   January 19, 2014, 08:06
Unhappy The P over the origin
magnus nytun
Magnus123456 is on a distinguished road
Hi
Just started to use Ansys fluent 14.5. When creating the geometry a P is supposed to appear when you point over the origin, but this does not happen in my case. Does anyone know if this is new with Ansys 14.5, or if it's fixable!
Thanks
Magnus123456 is offline   Reply With Quote
Old   January 19, 2014, 09:00
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
In sketch mode, you should have a tab called "constraints".
Here you will find the auto-constraints setting that seem to be turned off. Turn them back on.
flotus1 is offline   Reply With Quote
Old   January 19, 2014, 10:30
Thumbs up The P over the origin
magnus nytun
Thanks It's working now!
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[General] Slice origin as annotation in animation bozack ParaView 6 July 27, 2018 04:37
[Commercial meshers] Origin 0 0 0 has been moved while fluentMeshToFoam ishimotoj OpenFOAM Meshing & Mesh Conversion 4 May 20, 2013 04:53
Harpoon import issue (origin?) LiveandLetDrive Main CFD Forum 1 April 27, 2009 20:02
Coordinate of axis origin Tang FLUENT 0 October 4, 2004 16:38
