February 10, 2014, 02:48 |
I need to mesh this geometry .
ahmad
Rep Power: 14 |
Hi all .
I try to mesh this geometry : but i couldn't do that .. anybody help me with many thanks also I try to mesh this one but i don't have any idea ? |
February 10, 2014, 06:32 |
Javi
Rep Power: 16 |
The first one is easy. You only need to create O-grid mesh to approach your model
Maybe this thread can help you for second geometry: Multiple pipe in cylinder |
February 10, 2014, 06:35 |
ahmad
Rep Power: 14 |
February 10, 2014, 06:49 |
ahmad
Rep Power: 14 |
I try but i cant mesh the concentric region ?
February 10, 2014, 07:09 |
Javi
Rep Power: 16 |
February 10, 2014, 07:55 |
#6 | |
ahmad
Rep Power: 14 |
if you can help me by second one , I close to do the first one |
February 10, 2014, 08:00 |
Javi
Rep Power: 16 |
Your hot water inlet & outlet are "AIRIN" & "AIROUT".
February 10, 2014, 08:12 |
ahmad
Rep Power: 14 |
February 12, 2014, 05:20 |
#9 |
ahmad
Rep Power: 14 |
I try to mesh the second one , is it my bock ok ?
I plan to make o-grid on every small pipe , is it write ? tn file here : https://www.dropbox.com/s/f2p7owecy11ek3z/pp.tin |
February 12, 2014, 09:09 |
#10 |
Javi
Rep Power: 16 |
If you want to make the second geometry blocking you need to work much more than first one. I´m thinking about the best approach. Maybe with help and ideas from other users you can get it.
February 12, 2014, 11:34 |
#11 |
Javi
Rep Power: 16 |
In this link there's one approach for cold water zone blocking. However, this is not the best solution. There are a lot of elements with bad quality in the center.
https://www.dropbox.com/s/n3mkd8alve...20Exchange.rar |
February 12, 2014, 14:03 |
#12 |
Here is the my try (i don't see the support plate in model) :
Files : Drop box link https://dl.dropboxusercontent.com/u/...ojectfiles.zip Project 1: Without internal pipes meshed Project 2 : created surfaces for internal pipes but got the problem on one face Project 3 : made face to surface association for surface of one of the smaller pipes... |
February 12, 2014, 16:51 |
#13 |
Javi
Rep Power: 16 |
Thank you FAR for your blocking . But... this blocking doesn´t consider buffle PVC, am I right? I did an approach with this requirement but I´m not sure about it. For this reason, I merge vertices from first o-grid blocking to try to get blocking inside buffle to delete them and get cold water zone. Correct me if I´m wrong.
February 12, 2014, 21:25 |
#14 |
ahmad
Rep Power: 14 |
Thank you javi and far
I try to make the support plate but i cant |
February 13, 2014, 01:38 |
#16 | |
ahmad
Rep Power: 14 |
February 13, 2014, 05:49 |
#18 |
Javi
Rep Power: 16 |
Yes ahmad, you're right. I deleted the blocks but It was because I wanted to try other approach. You can change material as Far said.
February 16, 2014, 15:40 |
#19 |
Javi
Rep Power: 16 |
Hi all,
I´m trying a different approach. I´m thinking about manage central blocks to get baffle blocking form but I can´t get it. I´ve been trying merge blocks, split vertices.. but nothing. Maybe some of you can help me to do this approach. Or maybe, simply, It can´t be done this approach. Files |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ICEM] Hexa mesh, curve mesh setup, bunching law | Anorky | ANSYS Meshing & Geometry | 4 | November 12, 2014 00:27 |
[Workbench] Meshing and export mesh from STL geometry | alerfreire | ANSYS Meshing & Geometry | 0 | March 26, 2013 09:25 |
[ICEM] Problem making structural mesh on a surface | froztbear | ANSYS Meshing & Geometry | 1 | November 10, 2011 08:52 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
