[ANSYS Meshing] error in complex geometry
Old   February 17, 2014, 12:01
Default error in complex geometry
John
suchy_t is on a distinguished road
Hi everyone,
I am struggling with mesh in a complex geometry. I must meshing inside the jet engine.
PROCEDURE
- I created a solid body in the shape of the engine that I'm interested in.
- Next i did boolea's operation in Ansys Meshing (my box and engine shape, also solid).
-I generated a grid and it turns out that it was done only on the surface part and it shows two errors:
The mesh faces on the following topological surfaces may intersect with mesh faces on other topological surfaces in the model, Please use different mesh size, virtual topology or correct CAD geometry.
A mesh could not be generated using the current meshing options and settings. Hint: The problem geometry areas might have been highlighted. Switching to wireframe mode may make them more visible.
I use diffrent CAD format including STP, IGS, parasolid, Ipt and allways i have the same problems.
Any idea about how to approach this problem?
Thanks
suchy_t is offline   Reply With Quote
Old   February 17, 2014, 12:22
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
I would suggest you to import that geometry into ICEM CFD and delete unnecessary details and create additional surface if required.
Please show some pics...
Far is offline   Reply With Quote
Old   February 18, 2014, 04:32
John
thanks for the reply
ICEM shows the message: Tetin file ..... .tin does not exist if I try import both solids.
mesh should be inside the geometry
https://imageshack.com/i/0uk095g
[ANSYS Meshing] Meshing complex geometry cfdhydraulic ANSYS Meshing & Geometry 15 May 4, 2017 10:09
[GAMBIT] Internal Volume Meshing -- Complex Geometry JSolder ANSYS Meshing & Geometry 3 November 21, 2012 01:03
plane cutting complex geometry in the middle Lilly FLUENT 0 July 27, 2011 09:01
How to construct complex 3D geometry using GAMBIT? Feng FLUENT 5 October 11, 2005 04:13
Complex terrain geometry as using AutoCAD? Dai Phoenics 10 June 15, 2003 09:20
