[ICEM] discontinuous region over vorticity
Old   February 18, 2014, 11:49
Default discontinuous region over vorticity
jyh
jyh3134 is on a distinguished road
Hi, all
I've studyed 3d Wing recently
but I can't deal with some region where quantities show discontinuity especially Vorticity magnitude.
The reason I think is fine grid spacing near LE, wing tip without reasonable stretching ratio or asepct ratio caused by blocking topology.
But I want mesh refinement in there, and can't change blocking strategy.
(due to sharp TE and wingtip, I employed H-grid type.
here are details of simulation.
grid generation : Icem CFD multiblock hexa
(determinant quality above 0.4, angle > 0.3, no negative volume)
solver : fluent
Re=1.2e6
k-omega SST
node based, 2nd order, steady, AoA=8deg
Thanks in advance.
best&regards
jyh3134 is offline   Reply With Quote
Old   February 20, 2014, 07:30
Brian
gotang is on a distinguished road
Your problem is very clearly a mesh dependency issue, as the non-physical gradients that you observe align on your block boundaries. You say that you cannot change your block structure - why not? It is important to avoid the skewness that you have produced close to the LE of the aerofoil, due to the flow stagnation close by. If your aerofoil has a sharp TE, then you should use a C-grid around the aerofoil itself, which can then join on to an H-grid in the outer region.
gotang is offline   Reply With Quote
discontinuous region over Vorticity contour jyh3134 FLUENT 0 February 17, 2014 18:37
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 13:12
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 04:04
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 04:38
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
