February 28, 2014, 16:27 |
ICEM CFD: Interface Question
Brian Henry
Rep Power: 15 |
So, I've been using this for a while to generate meshes, and there is one question I have that I wasn't able to solve by looking at the documentation.
Is it possible to have different viewing properties per mesh part? As in I want to see part A as a solid surface, part B as a wireframe mesh, and part C as a wireframe mesh and a solid surface. I can assign them all a single display but it would be better for picture generation (or maneuvering through the mesh) to be able to assign individual display settings. Also, for solid surfaces, is there an option to change the transparency of the mesh? This was also something I wasn't able to find in the documentation, so I assume its a no. |
March 1, 2014, 00:52 |
Brian Henry
Rep Power: 15 |
Thanks! Will check out tecplot
display, settings, surfaces |
Future CFD Research | Jas | Main CFD Forum | 10 | March 30, 2013 12:26 |
Solid-fluid Interface question | shankara.2 | ANSYS Meshing & Geometry | 2 | September 14, 2011 12:49 |
ICEM CFD 11 interface in ProE wildfire 4.0 | seaning | ANSYS | 1 | July 14, 2009 03:04 |
Output Interface from ICEM CFD | sun | Siemens | 0 | June 21, 2005 12:59 |
ICEM CFD Modules | Boris | FLUENT | 1 | March 12, 2004 14:37 |
