Rep Power: 14 ![]() |
I'm meshing a 3d case
I can preview surface mesh But, I'm failed to build volume mesh I got following message: The following surfaces may intersect other surfaces in the model, Please mesh with a larger element size, use virtual topology or correct CAD geometry. What does this mean? How can I know which face got problem? Thanks in advance |
vidyanand
Rep Power: 17 ![]() |
you can click on the message and it highlight the body which one over lapping, If you are using design modeller then use share topology to understand the overlapping geometry just click on share topology and generate,
In mesh at the in outline at the model right click then u get the virtual topology then u can generate the virtual topology |
#3 | |
Thanks for your reply I have sorted it out in SolidWorks Initially the quality of my CAD model is not good enough |
[ANSYS Meshing] Extruding 2D mesh to 3D mesh in ANSYS meshing | Rachit | ANSYS Meshing & Geometry | 10 | February 14, 2024 08:19 |
[snappyHexMesh] SnappyHexMesh for internal Flow | vishwa | OpenFOAM Meshing & Mesh Conversion | 24 | June 27, 2016 08:54 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
Problem importing GAMBIT mesh to Ansys geometry | David G. | CFX | 0 | June 19, 2005 06:01 |
