[Workbench] Meshing Intersecting Geometry
Old   March 2, 2014, 20:15
Default Meshing Intersecting Geometry
Stephen
Stephen_W is on a distinguished road
Hey, so I've got a problem with meshing a 3d wing in a virtual wind tunnel in ANSYS Workbench.
I've got a solid tube that is the air volume, and from within it I've removed an area that represents the wing (so the surface around that missing area becomes the wall). However when I go to mesh it, the mesh intersects the surface and is very jagged, although only on one side (the leading edge). Everything else looks good, and I've tried everything I can think of without luck.
Any suggestions would be appreciated and I'd be happy to upload files if that would help.
EDIT:
I was asked to share the CAD files for the geometry. They can be found (currently in .SLDPRT format) at https://www.dropbox.com/sh/6b2k4wk633tj868/u7Sbx_HWSY that link. "AOA 0" is the solid body representing the wing, and "AOA 0 - WT" is a solid cylinder with the wing removed to represent the air domain and is what I (attempt) to mesh.
Stephen_W is offline   Reply With Quote
[ICEM] Meshing an irregular geometry Fabio Tabacow ANSYS Meshing & Geometry 6 May 7, 2014 16:03
[ICEM] Geometry Meshing protea ANSYS Meshing & Geometry 2 November 22, 2011 12:15
[ANSYS Meshing] Using more than one meshing method on a single 2D geometry robbierich90 ANSYS Meshing & Geometry 0 October 30, 2011 13:12
Need help on meshing this simple geometry nha1g08 ANSYS Meshing & Geometry 3 March 9, 2011 02:13
meshing geometry in gambit soundar FLUENT 1 January 7, 2005 02:59
