[DesignModeler] Parts and bodies in DM
Old   March 3, 2014, 17:59
Default Parts and bodies in DM
futureamour is on a distinguished road
Hi!!!
I have a question about modelling.Suppose we have to mesh one easy 2d geometry-say a quadrilateral.Then we split it in two adjacent quads(of equal size) that we wish to mesh with 2 different ways.Say the first one with triangular
unstructured cells and the second with a mapped structured quad mesh.Of course the two faces have to be conformable.So my question is,should I make(in SW and then name it in DM)
2 different surface bodies,so that I have "1 part,2 bodies" or "2 parts,2 bodies"?
I cannot fully understand what is the difference.
I hope I have made my point clear,so that someone can help.
Thanks in advance
futureamour is offline   Reply With Quote
Old   March 6, 2014, 09:55
vidyanand
Vidyanand Kesti is on a distinguished road
if you want conformal mesh on two bodies then these parts should be in one part, if you want non conformal mesh then put it in two parts...
Vidyanand Kesti is offline   Reply With Quote
Old   March 6, 2014, 10:04
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Originally Posted by futureamour View Post
Hi!!!
Thanks in advance
Two bodies and two parts will allow you to apply the different meshing on different parts. But mesh will not be conformal, as both parts are not connected to each other.
Two bodies and one part will allow you apply the different meshing on different parts and also make the mesh conformal at the interface of both parts.
To make one part, just select both bodies and form a new part. You can also use SEW command to form one part.
Far is offline   Reply With Quote
[Other] Connecting 3D bodies in Ansys Design Modeler chipper ANSYS Meshing & Geometry 4 January 25, 2018 09:45
[ANSYS Meshing] How to transfer bodies in FE Modeler to Initial Geometry goddy72 ANSYS Meshing & Geometry 2 March 11, 2015 03:18
[DesignModeler] Slice command does not preserve bodies jtipton2 ANSYS Meshing & Geometry 1 July 31, 2013 11:48
[ANSYS Meshing] Identical meshes in symmetric bodies in multibody part. aarvay ANSYS Meshing & Geometry 2 May 11, 2012 11:15
[ICEM] Multiple Bodies BrolY ANSYS Meshing & Geometry 2 July 5, 2010 11:04
