March 26, 2017, 15:06 |
General Questions
Rep Power: 13 |
Hey there,
I really struggle with ICEM and was hoping that someone here would be able to answer some questions to which I cannot seem to find an answer. In order to make answering easier I have subdivided the steps I have to undertake in ICEM, in order to obtain a mesh, in the following sub steps: 1. Accuracy/ Cleanness of the Geometry file 2. Blocking Strategy 3. Pre-Mesh/ Associations 4. Quality Check 5. Mesh Check For each of my sub steps the following questions were arising during the process and I was wondering if someone would be able to answer them. 1. Accuracy/ Cleanness of the Geometry file- How do I check if the geometry I would like to mesh is “good” enough?- Are there certain ways of creating i.e. delta wing? If so which are those? Are there any commands in CAD I should avoid when possible (i.e. lofting)- How can I repair faulty geometries? Which software should I use? 2. Blocking Strategy- Are there any tips or tricks to develop a blocking strategy? Or is it trial and error? 3. Pre-Mesh/ Associations- Does every edge and vertex have to be black or green (associated to either a face or a curve)?- If I load a blocking file into a new project and onto a different geometry will I need to redo every association? 4. Quality Check- How can I improve bad Determinant values?o Associate more edges?o Are there general rules of improving?- How can I minimise skewness? (I.e. for a delta wing as it would have skewed elements due to the nature of the geometry being a triangle)- Do I have to accept a certain level of bad quality elements? If so, how do I know which ones could be further improved? 5. Check Mesh- What causes penetrating elements and how can I fix them? |
ansys, icem, mesh check, meshing, quality check |
Constant Power Fan Model using General Momentum Source | Dano62 | CFX | 0 | April 14, 2016 13:09 |
Need advice/General questions | MrCaplin | FLUENT | 3 | March 2, 2016 17:36 |
General ellipsoidal geometry in Gambit? | LJB | ANSYS Meshing & Geometry | 1 | September 28, 2009 02:13 |
novice star ccm+ questions | apc3161 | STAR-CCM+ | 2 | August 25, 2009 10:15 |
GGI ERCOFTAC and general questions | david | OpenFOAM Running, Solving & CFD | 8 | August 25, 2008 09:22 |
