[ICEM] y+ structured vs. unstructed grid
Old   March 14, 2014, 07:19
Default y+ structured vs. unstructed grid
Jan Potac
potac is on a distinguished road
I have been playing with a simple 2D duct geometry. After the simulation with air flow I can observe that the y+ plot along the duct is smooth curve in case of structured grid, while the unstructured tetra with inflation layer shows a quite rough curve. The fluctuation is approx. 0.05. What is the cause of this and how to handle it?
potac is offline   Reply With Quote
Old   March 14, 2014, 07:36
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
There are reasons to get this difference:
1. Friction velocity
2. Distance of first cell
It is difficult to tell that which factor is influencing Y+ in the case of prism mesh. I would suspect first cell distance (dimensional)
Far is offline   Reply With Quote
Old   March 19, 2014, 23:50
Crank-Shaft's Avatar
Ovi
Crank-Shaft is on a distinguished road
If everything else in the simulation was exactly the same and the flow configuration was identical, then it could simply be the calculation of the wall-normal distances.
There might be some information in the ANSYS Fluent guide about the calculation of the first-cell distances and this could be the causing the difference. Additionally, you need to make sure that the transition between the prism layer and the first tetrahedral cell is quite gradual and the volume ratios or growth rates are also comparable to the structured, hexahedral mesh.
Hope that guides the thought-process a little bit better.
Mechanical Engineering
Sydney, Australia
Crank-Shaft is offline   Reply With Quote
Old   March 24, 2014, 04:21
Jan Potac
Thanks for the hints. The trouble was caused by a large volume gradient between the last prism and first tetra.
2d irregular grid Remy Main CFD Forum 1 December 22, 2008 04:49
3D structured curvilinear grid generator George Main CFD Forum 0 May 29, 2006 06:29
matrix solver about block structured grid young min, Sohn Main CFD Forum 1 July 11, 2000 19:35
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 11:18
How to Read Structured Grid in Fluent5? caihu Main CFD Forum 1 October 19, 1999 23:26
