April 7, 2014, 10:03 |
Prism layer issue
Rep Power: 14 |
Hi
I set the quantity of prism layer into 3 However, at the conner of building, the third layer vanished (probably I didn't use correct words to describe the problem, but you can see it clearly in the attached pic) Thanks for your help in advance |
April 7, 2014, 15:44 |
Stuart
Rep Power: 25 |
I'll take a guess from your picture, since the first two prism layers look the same height, that you did not float the prism layers.
If you did not then give that a try. Set the initial height and total height to 0 and just let ICEM build a few layers itself. There's lots of posts about floating prism layers if your stuck - particularly PSYMN's presentation/document. You'll want to be working to get enough prism layers for your simulation and a smooth volume transition between the last prism and first tetra - which is not what your picture shows. |
April 8, 2014, 02:32 |
Rep Power: 18 |
Set up "Max prism angle" to 180 (degree).
[ICEM] Steps of generating prism layer | TommyLui | ANSYS Meshing & Geometry | 2 | September 8, 2011 17:01 |
[snappyHexMesh] snappy hangs while layer generation | bastil | OpenFOAM Meshing & Mesh Conversion | 3 | October 29, 2010 07:19 |
Why only one prism layer generated | xiaoyoyo | ANSYS Meshing & Geometry | 0 | August 26, 2010 20:17 |
Prism layer advice needed for port flow case | MaxCFM | ANSYS Meshing & Geometry | 0 | October 2, 2009 08:42 |
errors | Fahad | Main CFD Forum | 0 | March 23, 2004 13:20 |
