[ICEM] import icem mesh into ANSYS APDL
Like Tree1Likes
  • 1 Post By nirjhor
Old   April 23, 2014, 02:15
Exclamation import icem mesh into ANSYS APDL
fariba k.
fariba is on a distinguished road
Hi everybody. I did my meshing using ICEM, I want to import it to ANSYS apdl. Now I have my mesh in .msh and .uns formats. Is there any way to convert it to a suitable format for apdl?
fariba is offline   Reply With Quote
Old   May 4, 2014, 12:36
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Well you have several options to achieve what you want, I give you one that I use.
If you're working with the WB then simply add a "FE modeler" and browse your .uns mesh that you've created with ICEM (you can select the mesh type, in your case .uns). Then simply link the FE modeler with ADPL and update it.
Gweher is offline   Reply With Quote
Old   May 8, 2014, 03:39
fariba k.
Originally Posted by Gweher View Post
thanks alot
Old   May 8, 2014, 12:32
Gweher's Avatar
Gwenael H.
You're welcome, glad it worked out.
Old   January 15, 2015, 15:57
Default Can not select lines or area.
Abdullah Al Amin
nirjhor is on a distinguished road
Hi Gweher,
I am preparing my mesh into ICEM, importing it into APDL according to your suggestion. It seems to load the mesh perfectly, but when I wanted to select areas/lines to apply boundary conditions, it says area/lines doesn't exists. Can you please let me know how can I make the mesh behave as it does when I run the analysis entirely from APDL?
Best,
Abdullah
Graduate Research Assistant
Case Western Reserve University
Alam Swift likes this.
nirjhor is offline   Reply With Quote
Old   May 21, 2016, 02:31
Alam Swift is on a distinguished road
Originally Posted by nirjhor View Post
Hi Gweher,
Best,
Abdullah
Hi Abdullah,
Have you found a way to solve your problem? Could you share with me about that?
Yours,
Alam
Alam Swift is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] 2D Mesh from ICEM to ANSYS FLUENT TomM ANSYS Meshing & Geometry 1 May 8, 2013 14:07
ANSYS ICEM CFD Mesh to Gambit Simon Bergström FLUENT 0 January 19, 2007 11:53
How to import mesh from Ansys? Achilleas FLUENT 6 August 9, 2005 10:59
