[ICEM] Blocking doesn't follow correctly when making minor changes to geometry
Old   May 25, 2014, 10:18
Default Blocking doesn't follow correctly when making minor changes to geometry
Polarbear is on a distinguished road
Hello all,
I have a small problem which probably has an easy solution but I can't figure it out. I need to do a parametric study of a geometry by changing the length of some pipes. I started a Workbench project and did the model in DesignModeler and coupled it to ICEM. My geometry is a large cylinder connected to a smaller cylinder which in turn is connected to a large cylinder.
I start with doing the blocking with multiple O-splits and associating the edges to the curves. I then have some curves that are not associated to curves but rather faces to surfaces(see attached figure). Everything works fine and I get the mesh that I want. When then altering the length of the smaller cylinder, e.g making it longer, then the blocking is of course not following but the associations still remain, I figured that if I associate the faces with the geometry surfaces and then snap the vertices, the blocking should just translate with the geometry. But the problem becomes that the blocking follows but doesn't retain its original form. Do you have any ideas for this?
Thanks in advance
Polarbear is offline   Reply With Quote
Old   May 25, 2014, 13:09
Nevermind, found the answer. I could just translate the blocks in ICEM the distance
[ICEM] O-grid around wing geometry Anorky ANSYS Meshing & Geometry 15 November 27, 2017 13:43
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
Problem in Initializing Blocking for 2d geometry nitin Dewangan CFX 6 October 24, 2008 01:03
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
Virtual/Real geometry. Jack Keays FLUENT 9 June 15, 2000 23:39
