[ICEM] ICEM mesh to FLUENT, body not present in FLUENT |
June 10, 2014, 08:48 |
Thibault
Rep Power: 12 |
I made this mesh in ICEM CFD around a NACA0015 airfoil. When I was done I exported it to FLUENT. The wing which I set as wall was not visible and not taken into account for the simulation. What can cause this? Here you can see the mesh I made in ICEM CFD: This is what I got in FLUENT And here you can see that 'wing' was not passed on to FLUENT. ICEM: FLUENT: It might have something to do with this. When I change one of the vertices on the wing the surface-color changes to symmetry plane instead of wall.. Any idea why this is? Thanks! |
June 10, 2014, 15:39 |
Ion
Salut Thibalt,
I know that when you do a mesh in ICEM CFD for Fluent you must set de BC for export...try this and i sure that your problem is no more....) |
June 11, 2014, 03:29 |
Thibault
Rep Power: 12 |
Thanks for the reply, those BC are properly set, so the problem still exists :/
June 11, 2014, 05:13 |
Thibault
Rep Power: 12 |
I fixed the problem with the surfaces in the last picture.
I forgot to press repair geometry after I've put in the body. The wing is still not showing up in FLUENT however.. |
June 11, 2014, 12:33 |
Ion
you can send the Icem files to see better the problem?
June 11, 2014, 12:45 |
Thibault
Rep Power: 12 |
Thanks for your reply, I blocked the enclosure first and added the geometry later on, such that I can easily load in other geometries without doing the blocking all over again. I think that caused the problem.
Eventually I deleted the blocks inside the wing, which updated the .uns file. It's not really a solution, more a work around. I'll just stick to this, it works for me, thanks anyhow! |
fluent, icem cfd, mesh 3d, naca 0015, wing |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
Export mesh from ICEM CFD for Fluent | summerdream | ANSYS | 2 | September 10, 2013 12:12 |
GENERATE MESH IN ICEM and OPEN IN FLUENT 12 | Galileo | FLUENT | 10 | September 6, 2013 13:26 |
Transport mesh from ICEM CFD, to Fluent, to Sysnoise | Wieland | FLUENT | 2 | April 15, 2012 06:28 |
2D mesh in ICEM to read it in Fluent | Alshroof | FLUENT | 1 | February 22, 2007 08:49 |
