June 13, 2014, 07:31 |
multi fluid zones
harika
hi !
i am trying to make an unstructured grid in icem cfd with two fluid zones. but all the time i am getting geometry hole error. kindly help me |
June 19, 2014, 08:51 |
Yon Han Chong
Rep Power: 14 |
There are a number of reasons why it could happen so it would be helpful if you post the screenshot.
By the way, how did the geometry created and imported into ICEM? I found that the Parasolid format gives me the least problems in terms of surface gap. Also if you have curved surface check your model tolerance. Settings -> Model/Units -> Triangulation. If the tolerance is bigger than your small feature, ICEM will struggle to fit any cell there and you could have strange results. |
June 19, 2014, 11:25 |
harika
yeah i have imported the geometry from parasolid file ... the actual problem is i am trying to make grid for virtual blade model where i have to give to fluid zones .. i was trying it by creating to two volumes and as i have mentioned am getting the mesh hole error...
and then i have tried to extrude mesh for the disc but still on importing it in fluent the disc region is not automatically changed to wall zone instead of interior ..... help help !!! |
June 19, 2014, 14:19 |
Can you clarify?
#4 | |
Yon Han Chong
Rep Power: 14 |
So you want interior wall instead of wall or is it the other way around? You can change boundary type from wall zone to interior or interior to wall in Fluent but the volume mesh need to make sense. Wall boundary condition has only one side cell attached and interior has both side. |
[Other] Multiple internal wall an fluid zones | miles_davis | OpenFOAM Meshing & Mesh Conversion | 11 | November 28, 2016 07:11 |
Multi Fluid | david | FLUENT | 0 | March 8, 2007 08:36 |
My Revised "Time Vs Energy" Article For Review | Abhi | Main CFD Forum | 2 | July 9, 2002 09:08 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
surface-creation on 1 of 2 overlapping fluid zones | Volker Pawlik | FLUENT | 0 | November 17, 2000 05:15 |
