[ICEM] really sharp surface between wing and body
Old   March 24, 2019, 23:07
Default really sharp surface between wing and body
MarkTang
NCKU5566 is on a distinguished road
Recently i am trying to mesh F-16 model with icem like shown.
The surface mesh is no problem, but there are some really bad volume mesh after i extrude volume mesh with existing surface mesh(delaunay or fluent mesh), some terrible volume mesh show up. I can't grow prism mesh because the volume mesh is too bad.
I had try to grow prism before using delaunay, the prism can be done, but the delaunay not.
If i use orctree with existing mesh, the volume mesh always extrude into the solid part.
The bad part is at the junction between wing and body, there is a really small gap like shown.
https://imgur.com/sRMLZrq
https://imgur.com/IdBUFcz
https://imgur.com/QmvRBXc
https://imgur.com/vIjfj6A
NCKU5566 is offline   Reply With Quote
Old   March 26, 2019, 08:34
shereez234's Avatar
M Sereez
shereez234 is on a distinguished road
Hi there.
You have multiple curves on your wing to fuselage intersection area. The line elements on fuselage curve and wing curve don't match. Please rebuild your geometry topology or manually re do that bit.
shereez234 is offline   Reply With Quote
Old   March 27, 2019, 00:41
MarkTang
Originally Posted by shereez234 View Post
Hi there.
hi, shereez234!
Thanks for the reply. This model was downloaded on the internet, i'm not very willing to change it, but rebuild the gemotery seems to be the only solution.
How To Create Fowcs William Hawkings Surface in Fluent? marinkobezu FLUENT 7 October 25, 2018 10:51
Ahmed body simulation gives unexpected results in su2 6.0 anas651 SU2 0 March 28, 2018 03:42
[ANSYS Meshing] Meshing fluid around sharp edges of a 3D insect wing. minglis ANSYS Meshing & Geometry 1 February 2, 2017 09:14
Wing FSI simulation: Shell elements or 3D solid body? frossi CFX 3 June 15, 2016 20:02
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
