[ICEM] Vertex location
Old   August 8, 2014, 12:05
Default Vertex location
Govindaraju
kmgraju is on a distinguished road
Hi all
How to fix the the vertex as a perfect square after O grid blocking.
Thank you
kmgraju is offline   Reply With Quote
Old   August 9, 2014, 10:54
Sebastian Engel
bluebase will become famous soon enough
you could try creating points on the circle's arcs the following way.
# use create point on curve to get a point at 50% length of each arc. (to have 4 corner points of the square)
# copy and rotate the 4 points on the circle by 45 degree around the axis of the cylinder
Then, associate the outer vertices to the points.
For the o-grid points, i would first try to realign the o-grid vertices with the boundary vertices and reset the o-grid thickness.
If the result is dissatisfying, i would create a local coordinate system and move the vertices by coordinates.
With regards,
Sebastian.
bluebase is offline   Reply With Quote
Old   August 10, 2014, 02:42
Govindaraju
Originally Posted by bluebase View Post
With regards,
Sebastian.
Hi
If the geometry is not along the axis how to rotate the point on the curve
Thank you
Govind
ill defined primitive entry 'boundary' francisco.angel OpenFOAM Pre-Processing 16 September 8, 2022 06:11
[mesh manipulation] Mesh Refinement Luiz Eduardo Bittencourt Sampaio (Sampaio) OpenFOAM Meshing & Mesh Conversion 42 January 8, 2017 12:55
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 10:27
[CAD formats] my stl surface is seen as just a line rcastilla OpenFOAM Meshing & Mesh Conversion 2 January 6, 2010 01:30
NACA0012 geometry/design software needed Franny Main CFD Forum 13 July 7, 2007 15:57
