[ANSYS Meshing] multi body
Old   August 10, 2014, 05:48
Question multi body
Sa.Baraty
sara22 is on a distinguished road
Hello guys
I new at Ansys meshing. i model one shell and tube heat exchanger in design modeler for simulate in fluent.
for attach more quality mesh i have to slice fluid body to three section (three body).
so i have question that i must define particular boundary condition between this sections(three body are )?
thanks
sara22 is offline   Reply With Quote
Old   August 16, 2014, 17:13
jack robs
sa_m is on a distinguished road
hello
no .you must not.
in design modeler and in ((tree out line)) , right click on all three bodies and select ((form new part))
by this way, you can mesh each part with an optional setting and boundaries are perfect matched.
regards
sa_m is offline   Reply With Quote
Old   August 16, 2014, 18:51
jack robs
also you can see this
http://www.cfd-online.com/Forums/ans...h-failure.html
Old   August 18, 2014, 08:39
Sa.Baraty
tanks about your ans. if when i separate fluid body(three body-as new part) fluent detect boundary between solid and fluid domain as a shadow?(coupled wall between solid and fluid domain)
thanks
6dof model - floating body flinde FLUENT 13 March 6, 2021 14:32
multi Body Simulation harshalh Main CFD Forum 0 August 1, 2014 11:24
Double Body Simulation harshalh Main CFD Forum 0 July 31, 2014 05:36
[Need some advise] Am I doing right?? Simulating a rotational mixer setasena STAR-CCM+ 4 March 10, 2013 10:32
Multi body part and fluctuating residuals tichaona Main CFD Forum 0 February 7, 2012 13:09
