[ANSYS Meshing] Face Sizing
Old   September 15, 2014, 08:48
Default Face Sizing
Javi
FJSJ is on a distinguished road
Hi all,
I'm learning about Ansys Meshing because before I have only used ICEM CFD to create cfd meshes. So, maybe, this question is a easy one but I would like to know about your experience with that issue.
I just want to know why when I applied a "face sizing" in a specific face I get that result (see picture). I would like to get all the face sizing through all the select surface. I suppose that, one reason, It could be because global mesh control but I would like to know what are your suggestion to this behaviour.
Thank you in advance!
FJSJ is offline   Reply With Quote
Old   September 15, 2014, 09:21
amin.z's Avatar
Amin
amin.z is on a distinguished road
hi
as you said, I think a stronger sizing than the face sizing is reason this condition!
I guess you must control the shared edge as you want! maybe applying an appropriate edge sizing at the edge could help you!
amin.z is offline   Reply With Quote
Old   September 15, 2014, 09:39
Javi
Hi Amin,
Yes, I did it as well and It worked! I used a edge sizing in that edge and now I have more uniform mesh around the face. But, I just wanted to know if is necessary uses other controls to get the real "face sizing" that I wanted from the beginning.
Thanks
Old   September 15, 2014, 09:49
amin.z's Avatar
Amin
because the edge is belonging to both of the faces, the mesh on 2 sides of the edge must be almost the same!
so I think if you want one of the faces has an uniform mesh, you should ignore from the other face uniform meshing!
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
