[ANSYS Meshing] Two Domains - Interface Recognized
Old   September 23, 2014, 09:30
Lightbulb Two Domains - Interface Recognized
Daniela Passos
danielapsat is on a distinguished road
Hello, good morning.
I created a tetra mesh that have two fluid domains (oil and water). How can I create a material point or body in the tetra mesh for that the interface of the two domains be recognized by CFX-Pre?
Can anyone help me? Thanks in advance.
danielapsat is offline   Reply With Quote
Old   September 23, 2014, 11:27
amin.z's Avatar
Amin
amin.z is on a distinguished road
hey!
I don't understand your goal fully! but if you want using an interface between 2 faces of 2 various zone, you must define a connection between the faces in ANSYS Meshing!
amin.z is offline   Reply With Quote
Old   September 23, 2014, 11:49
Lightbulb
Daniela Passos
Amin.z,
My problem is a catenary riser with a marine domain around. But I need study a fluid flow inside of the tube with a presence of leak orifice through which the fluid will leave and I will can study the dispersion on the sea. The difficulty is the CFX-Pre recognize the interface between the tube and the marine ambience once the two domains will be fluids.
---- Thanks
Originally Posted by amin.z View Post
hey!
Old   September 23, 2014, 12:43
amin.z's Avatar
Amin
still unclear!
do you have one face at face of tube and want to have 2 separate faces!?
or
you have 2 separate faces, but you want define an interface between them and CFX does not recognize them?
Old   September 23, 2014, 14:06
Lightbulb
Daniela Passos
Yeah... I want define an interface between them... it's just one shared surface that I define as "wall" at CFX-Pre but CFX doesn't recognize as "internal fluid - wall" and "wall - external fluid"...
still unclear!
or
Old   September 23, 2014, 15:17
amin.z's Avatar
Amin
You should have 2 separte faces between the zones!
Do you use Ansys geometry for modeling? Do you use form new part in its?
I don't know about setup in cfx, but in fluent we should have 2 different faces and connect them in ANSYS meshing with using connect!
Old   September 24, 2014, 07:36
Daniela Passos
Ok, Thank you!! I will try this!!!
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
