September 24, 2014, 05:04 |
2D Surface Mesh
Hello guys!
first of all, sorry for my bad english i have to mesh a 2D geometry (attachement) 2d geometry.png air flows into the chamber and should pass the dashed lines to flow out. The dashed lines are closed in the geometry. In fluent i will appropriate the boundary condition (interior) to them, so the air can flow throuh. my problem ist that i should create 3 regions (attachement). So i created three surfaces and meshed them. The result was rubish (attachement) mesh.PNG the nodes of regions 1 to 3 are not overlapping. They should overlapping or? This is my first 2D surface mesh. how can i get overlapping of the nodes. In 3D geometries i used fluid points. Should i used fluid points in 2D geometries ,too? Are there other possibilities to create 3 fluid regions? How can i mesh them? Thank you for your efforts! |
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner | panpanzhong | OpenFOAM Meshing & Mesh Conversion | 5 | July 3, 2018 05:53 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
