[ICEM] How to import .msh mesh and edit it in ICEM?
Like Tree4Likes
  • 2 Post By Gweher
  • 2 Post By VSass
Old   November 12, 2014, 06:18
Default How to import .msh mesh and edit it in ICEM?
Wizze is on a distinguished road
Hi everybody
I have fluent mesh (.msh) that I have successfully imported to ICEM. Now I want to edit it, more specifically I want to change the resolution/lower the number of nodes. I can't find a way to do this as the blocking tab is not accessible(it is shaded grey). Any suggestions?
Thanks
Wizze is offline   Reply With Quote
Old   November 12, 2014, 11:02
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
You can't do that, you don't have the geometry, the mesh is already generated. The only thing you can do is to modify it in the mesh tab. you can refine, translate and many more...
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   June 30, 2020, 11:39
CFDger is on a distinguished road
What if I created the mesh in a different Workbench and want to edit this mesh in a different Workbench Project?
When I try this I have the same problem as Wizze.
Thanks a lot!
CFDger is offline   Reply With Quote
Old   July 1, 2020, 03:24
Gweher's Avatar
Gwenael H.
Gweher will become famous soon enough
Ali is right; you can only edit a mesh file with the predefined mesh tab in ICEM.
Well if you have the system geometry file as well, you can obviously change / edit the mesh in the different Workbench project. If you want to edit a mesh from a mesh file (.msh / .uns) in ICEM you just have the mesh tab option. If it’s a “minor” edit, say change some node alignment / position / symmetries you could manage with those tools, but if you want to completely change the mesh topology it doesn’t make sense to start from the mesh.
In case you ended up with only a mesh file without the source geometry, you can still regenerate the geometry from a mesh file (can cause some feature loss) and then remesh.
With the new workbench releases, starting from 2019R2 (if I remember correctly), you can also directly export a ICEM .prj including the .tin geometry file and .uns (File > Export > Mesh > ICEM) which will allow you much more flexibility.
Have fun
CFDger and aero_head like this.
Gweher is offline   Reply With Quote
Old   July 2, 2020, 03:28
VS
VSass is on a distinguished road
The easiest way to do it, without the source geometry, is to use the option Mesh->Facets in ICEM. This will create geometry entities with some loss of detail, as stated above, depending on the complexity of your domain. You can then remesh.
VSass is offline   Reply With Quote
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] Edit .msh file (Fluent) in ICEM CFD Keizers ANSYS Meshing & Geometry 5 February 24, 2013 13:07
ICEM Edit Mesh blackbody ANSYS Meshing & Geometry 3 March 8, 2010 02:49
icem: import tecplot mesh David CFX 4 August 9, 2006 08:30
How to do Geometry from 3D mesh in ICEM San24 Main CFD Forum 4 August 8, 2005 02:49
