[ANSYS Meshing] Problem with meshing large model |
February 3, 2015, 04:35 |
Sunil Krishna
Rep Power: 14 |
I'm working on a project which has one acre pond and large number of piping connections. The pipe size vary from 0.5 inch to 4 in dia.
I need to do multiphase modeling of air and water interaction from the porous pipe n water in the pond. I have done modeling in design modeler n performed Boolean operation to subtract the pipe from pond and then filled the hole area to form pipe. I'm not able to generate mesh even if I give small element size. It says to change the element size or apply virtual topology. Can anyone help me out with this prob? |
February 3, 2015, 17:09 |
Rep Power: 14 |
Could you post your geometry to give us a better idea, why and how it is failing to mesh?
Cheers KAPI |
February 10, 2015, 09:49 |
Geometry file
Sunil Krishna
Rep Power: 14 |
Pls find this link for step file geometry ( https://www.dropbox.com/s/xq76f7tpp6...ystem.stp?dl=0 )
Let me know if there are any issues with the geometry and whether the mesh is getting generated or not. Sunil |
[ICEM] Problem with meshing half NACA0009 in 3D | Eizo | ANSYS Meshing & Geometry | 30 | February 17, 2013 02:40 |
Mixture model problem - could someone please advise? | matlab_monkey | FLUENT | 2 | July 26, 2012 08:20 |
the combustion model problem | hanshandiaoke | Siemens | 0 | November 25, 2011 20:37 |
Problem with meshing long, thin faces in CFX | Martin | CFX | 3 | January 8, 2009 20:51 |
Meshing problem in GAMBIT | Vidya Raja | FLUENT | 0 | May 20, 2006 23:31 |
