[ANSYS Meshing] Having trouble meshing: No matter what mesh settings, always getting errors. |
February 25, 2015, 02:17 |
I'm trying to mesh a model of a car for Fluent CFD. No matter what mesh settings I use, I am always getting errors. With mesh sizes I realistically want to use, I mainly get these 3 errors:
Can someone please give me a direction? I've uploaded the parasolid of the car model I'm using: https://www.mediafire.com/?wdyhk79ch0ng673 |
March 9, 2015, 16:54 |
bump anyone?
March 10, 2015, 03:33 |
Amin
hey
what is your meshing strategy!? body sizing?sweep? or... maybe your mesh size is too large or maybe your mesh have a logical problem! and use right click on error messages and show problematic geometry |
March 11, 2015, 00:13 |
I think number of elements are too large and with big size elements it is not able to mesh it.
I reckon you shud do mesh it in few parts or simplify your geometry and try |
March 16, 2015, 04:01 |
Paritosh Vasava
Rep Power: 22 |
Instead of 'Curvature' switch to 'Fixed'. Then play with the element size vales. If you need finer mesh in some areas then try imposing 'sizing'.
September 6, 2016, 03:34 |
Nomen Ose
Rep Power: 10 |
Hey i have the exact same problem when meshing my geometry and my meshing strategy is Infiltration. Could you please help me with this?
September 6, 2016, 04:52 |
Paritosh Vasava
Rep Power: 22 |
Of course!! Thats what this platform is for. You can describe your problem and we can see what we can do.
September 6, 2016, 05:36 |
Nomen Ose
Rep Power: 10 |
I'm trying to mesh a model of a bus and outside geometry using CFD CFX. No matter what mesh settings I use, I am always getting errors. With mesh sizes I realistically want to use, I mainly get these 3 errors:
The following entities failed to mesh. The meshes of the bodies containing these entities are not up-to-date. However, meshing may be successful on the other entities. The following surfaces cannot be meshed with acceptable quality. Try using a different element size or virtual topology. A mesh could not be generated using the current meshing options and settings. I have attached a couple of pictures to further clarify my problem. Regards, |
September 6, 2016, 07:24 |
Paritosh Vasava
Rep Power: 22 |
To you also, I would give the same advise: Instead of 'Curvature' switch to 'Fixed'. Then play with the element size vales. If you need finer mesh in some areas then try imposing 'sizing'.
September 8, 2016, 06:16 |
Nomen Ose
Rep Power: 10 |
Thanks for your help! I made those changes but still getting the same errors
September 8, 2016, 06:17 |
#11 |
Nomen Ose
Rep Power: 10 |
What else can I do to fix this ?
September 9, 2016, 01:40 |
#12 |
Paritosh Vasava
Rep Power: 22 |
Firstly, could you list the changes you made? This way we can make sure that you are not making changes haphazardly and try things in a sequence.
Next,
September 16, 2016, 22:28 |
#13 |
Nomen Ose
Rep Power: 10 |
Thanks Vasava, I applied these changes and my mesh seems to work well.
Regards, |
[snappyHexMesh] problems generating clean mesh | Christian_tt | OpenFOAM Meshing & Mesh Conversion | 2 | June 20, 2019 05:39 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 10:08 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
