[DesignModeler] Boolean operation failed
Old   March 9, 2015, 16:09
Default Boolean operation failed
Aberdeenshire
pogbodo is on a distinguished road
Hi everyone,
I'm in need of urgent help pls.
I tried creating a boolean subtraction, i.e, to subtract the cylinder surface from the rectangular domain as in the picture below, but it didn't work. Could someone explain how I could do this.
Thanks
pogbodo is offline   Reply With Quote
Old   March 10, 2015, 03:30
amin.z's Avatar
Amin
amin.z is on a distinguished road
hey
do you set correct setup for boolean setting? what is target and tool bodies!?
amin.z is offline   Reply With Quote
Old   March 10, 2015, 10:54
Aberdeenshire
Hiya,
Yes, I did. The target body is the rectangle's surface body, and the tool body the cylinder's. I think the problem is, because the cylinder rests on the rectangle it cannot subtract.
Is there any other way I can perform flow over a cylinder with that setup without performing a boolean operation.
Thanks for your kind help.
Old   March 10, 2015, 12:58
amin.z's Avatar
Amin
maybe!
anyway, you can use "cut material" in cylinder part
Old   March 10, 2015, 13:07
Aberdeenshire
Sorry, that didn't work either.
Old   March 11, 2015, 00:11
Kapi is on a distinguished road
the problem cud be that both are sharing same surface!
Try to make separate part for each and then Boolean it.
also can you check what error it is giving when you are trying to Boolean it?
Kapi is offline   Reply With Quote
Old   March 11, 2015, 03:03
Aberdeenshire
Hi Kapi,
They are different parts.
The warning message is:
Operation would result to non-manifold bodies.
Context: Geometry Engine; while generating Feature Boolean1
Thanks for your help.
Old   March 11, 2015, 04:46
amin.z's Avatar
Amin
your sketch is simple! you can draw all of them in one part! without boolean or cut material! draw your rectangle and circle in one part and use "trim".
Old   March 11, 2015, 05:11
Aberdeenshire
Hi Amin,
I don't understand. Is the use of trim not applicable to lines? Well, I tried it as suggested but it trimmed off the lines of the circle.
I want to remove the circular surface from the rectangle, but it results to 0 thickness where the circle intersects with the rectangle. Hence the error message of non-manifold body. I am sure there is a way around this, which I don't know.
Regards.
Old   March 11, 2015, 07:05
amin.z's Avatar
Amin
it isn't clear! if you want you can give me your model dimension and I will try to evaluate it...
Old   March 11, 2015, 08:08
Aberdeenshire
Hi Amin,
Sorry, I'm new to modelling hence I don't understand much.
I have attached the geometry below.
Regards
Old   March 11, 2015, 08:12
amin.z's Avatar
Amin
Originally Posted by pogbodo View Post
Hi Amin,
Regards
Attachment 37734
no problem friend!
now I'm in my office, when I came back to the home, I will find a free time and evaluate it...
Old   March 12, 2015, 01:45
amin.z's Avatar
Amin
well
the problem solved! there are different ways to design this sketch
a simple way:
draw main rectangle with these dimensions: 600*210 mm (20 mm below the x axis)
draw the circle: R=20mm
do a boolean
draw a fake rectangle from tangent to the circle ( 10 mm below the x axis)
subtract fake rectangle from main rectangle
Old   March 12, 2015, 17:26
Aberdeenshire
Hi Amin.z,
Thank you so much for your help. I truly appreciate it.
Regards,
Precious.
Foam::error::printStack(Foam::Ostream&) with simpleFoam -parallel U.Golling OpenFOAM Running, Solving & CFD 52 September 23, 2023 03:35
Initial conditions for uniform flow andreas OpenFOAM 5 November 16, 2012 15:00
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 09:54
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
