[DesignModeler] Problem With Surface Bodies While Importin IGES file from CATIA
Old   April 28, 2015, 02:37
Default Problem With Surface Bodies While Importin IGES file from CATIA
UKS
Unnikrishnan S
UKS is on a distinguished road
I am having this problem that i get only surface bodies when i generate Assembly files from CATIA in IGES format. I am getting Part bodies for some files.
I need to know how i could make sure to avoid this problem.
With Regards
UK.
UKS is offline   Reply With Quote
Old   April 29, 2015, 05:39
sly
saltoh101 is on a distinguished road
What version do you use of WB?
saltoh101 is offline   Reply With Quote
Old   April 29, 2015, 22:49
Kapi is on a distinguished road
Hi UKS,
I suggest use "Parasolid" format and this problem can be avoided
Cheers
KAPI
Kapi is offline   Reply With Quote
ansys 15.0, design modeller, igs, import geometry, surface body
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 10:03
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 01:22
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 09:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
