[ANSYS Meshing] refine mesh in volume of model? |
April 29, 2015, 02:33 |
Hydreaulic structures
Rep Power: 14 |
hi all
i want refine mesh in area of volume that i shown in figure with red color, please guide me, how do this??? i know i can using refinement or sizing, ...) but they dont solve my problem bacause only refined surface no volume, and using body spacing number of cell very high, whether exist way for refined this volume? thanks Last edited by hamidciv; April 30, 2015 at 01:35. |
April 29, 2015, 18:27 |
Rep Power: 14 |
Hi Hamidciv,
Have you tried sphere of influence? to give sizing in the red circled area, I suggest use "Sphere of influence" Mesh>Sizing>Type>Sphere of Influence or Body sizing is another option if you have different parts in your design and you want specific part to be meshed fine! To check the mesh inside volume, you can slice it and see how is the mesh! for that go to "Section Planes" and slice your volume from center to see mesh inside! Hope it helps Cheers KAPI |
April 30, 2015, 01:31 |
Rep Power: 14 |
hi dear kapi
thanks a lot for help me, in your opinion what kind of mesh is efficient for my model? whether you suggested tet/inflation as shown figure? are you agree with tet or hex mesh in this model also In general? are really hex mesh used less element compared to tet mesh and give same resolution tet mesh? best regards hamidciv Last edited by hamidciv; April 30, 2015 at 10:34. |
April 30, 2015, 19:50 |
Rep Power: 14 |
Hi Hamidciv,
Yes Hex mesh gives less number of elements as compared to Tet mesh because Hex mesh is structured whereas Tet mesh is not. To get similar accuracy you will need lot more Tet elements as compared to Hex elements which increases your model size and in turn increases time of computing. You may refer to this 'thread' to compare Tet and Hex mesh!! For your model specifically I say Hex mesh will give you similar result with less elements and faster computing Hope It helps Cheers KAPI |
May 1, 2015, 11:32 |
Rep Power: 14 |
thanks for help me dear kapi
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 17:22 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
