[ICEM] SAE Reference Notchback model - diffuser mesh and index control
Old   May 7, 2015, 21:17
Default SAE Reference Notchback model - diffuser mesh and index control
Crank-Shaft's Avatar
Ovi
Crank-Shaft is on a distinguished road
Hello CFD Onliners,
Hope you are going well with your respective projects.
I've been working with a SAE notchback reference model with 20 degree. backlight angle. The current mesh was created by covering the diffuser section with planar surfaces, then starting with 2D surface meshes and extruding and converting to a 3D mesh. This was then mirrored about the longitudinal plane of the car model and led to 828 blocks. The current required file output is CGNS for our in-house CFD solver.
Now I'd like do some simulations with the actual diffuser to understand how it alters the flow in the wake of the car. Here are the main challenges faced -
a) The index control for this mesh doesn't work very well to isolate the bottom-rear of the car so that the lower blocks can be split.
b) Finding a block layout and topology that doesn't lead to high levels of skewness and gigantic aspect ratios or a Y-block for the diffuser section.
I'd really like to include the diffuser and I realised that going back to the half-car model to the pre-mesh stage and then modifying the existing blocks is the only way. Then I plan to mirror the final mesh prior to CGNS export.
Here are the relevant .tin, .blk and .prj files for icem. FILES
Looking forward to all your suggestions and advice.
Mechanical Engineering
Sydney, Australia
Crank-Shaft is offline   Reply With Quote
Old   May 7, 2015, 21:24
Ovi
Here are some images.
Sydney, Australia
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 00:58
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 13:32
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
