May 17, 2015, 02:52 |
Meshing failure over Aileron
Sandeep
Rep Power: 13 |
hi friends ,
i have a wing geometry with cutouts for flap and aileron the gap (uniform) between flap and aileron is 11 mm the min gap b/w wing & flap is 8 mm the min gap b/w wing and aileron in 2 mm the topo tol. in ICEM is 2 mm which is giving all curves as RED ! i am going for an unstructured , tetra (Octree) mesh ! i am facing the following problem : 1. the aileron does not get meshed in the sense that the mesher does not see it as a 'cavity' in the domain, WHY this happens ,and HOW to correct it ? ..any ideas from you side ? thanks Sandeep |
[ANSYS Meshing] Meshing Failure for four geometries | bnicholls92 | ANSYS Meshing & Geometry | 0 | November 14, 2013 13:37 |
Meshing problem --> Thermo failure | erichu | Mesh Generation & Pre-Processing | 0 | April 8, 2013 10:59 |
[GAMBIT] 3D Cooper Meshing failure | ritwik | ANSYS Meshing & Geometry | 0 | December 1, 2010 07:04 |
Volume Meshing & Face Meshing? singularity of grid | ken | FLUENT | 0 | September 4, 2003 11:08 |
