gautham narayan
Rep Power: 11 ![]() |
I have a problem in ICEM cfd that I have been trying for almost 3 weeks now, without any success. It would be very helpful if someone can point out where I could be going wrong. i am attaching my a screenshot of the incorrect 2D mesh but it is hard to find out the mistake from it.
the mesh looks fine to me but when doing a mesh check it says, that there are overlapping elements, on viewing the subset it shows the overlapping elements highlighted, but on deleting them there is no other elements there. i understand that the icem thinks that there are two boundaries there, when actually there is only one. how do i correct this. i am attaching my geometry and blocking file if someone could help me out with where i am going wrong. thanks a lot |
Sebastian Engel
Rep Power: 21 ![]() |
Hi Goutham,
first.. please consider posting in the right subforum next time, you might get help easier. There is a subforum dedicated to meshing with Ansys products. Anyway... Open your project and make blocks visible. Then check for distorted or collapsed blocks. Probably, you will spot the problem easily. Have a look at the following screenshot: snapshot1.jpg Can you find your problem? No? There is a collapsed row of blocks (# 39). Remove this row of blocks and this problem should be solved. I think there is also a mesh check which creates a subset with problematic elements. With this subset it might be easier to spot regions with faulty blocking. With regards, Sebastian |
[ICEM] Icem CFD on Linux | mechanicaldesign | ANSYS Meshing & Geometry | 7 | March 11, 2021 19:44 |
Need help icem cfd | kakhtar | ANSYS Meshing & Geometry | 25 | January 31, 2017 01:09 |
Transport mesh from ICEM CFD, to Fluent, to Sysnoise | Wieland | FLUENT | 2 | April 15, 2012 06:28 |
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent | ivanddd | ANSYS Meshing & Geometry | 1 | February 3, 2011 00:51 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
