[ICEM] Blocking Strategy help required in meshing a half model aircraft (3D, UAV) |
July 29, 2015, 03:39 |
Nikesh Bhattarai
Hello folks,
I have been trying for weeks to come up with a blocking strategy to mesh this beauty (Fig1). Fig2 shows the entire computational domain. Fig3 is where I have tangled, like stuck in a spider web soon to be its feast. Fig4: The connector region is so difficult to block. I haven't figured out a way to block it, especially because it is connected both to the main and tail wings and goes normal to the wing surface. Fig5: The tail which has anhedral angle and goes from the top of the vertical fin to the connector. Fig6: Wing-fuselage joint section has similar geometry to that of the connector region and I believe has the same solution to that of Fig4. Any help highly appreciated. Thanks a lot. Nikesh. |
[ANSYS Meshing] Blocking and Meshing around a vane vortex generator | Crank-Shaft | ANSYS Meshing & Geometry | 5 | January 17, 2016 23:29 |
[ICEM] suggestion for blocking strategy and meshing a corner | Daniel_Khazaei | ANSYS Meshing & Geometry | 26 | November 12, 2013 05:26 |
[ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 03:13 |
Half laminar and turbulent model trying to solve | Andrew Clarke | FLUENT | 5 | May 19, 2008 13:40 |
Kinetic air props model - conductivity HALF? | Chris Bailey | FLUENT | 1 | March 7, 2006 10:38 |
