[ICEM] Control of tetra meshing
Old   August 3, 2015, 11:20
Default Control of tetra meshing
Benjamin
Benzouz is on a distinguished road
I have a beginner question about how to have a full control of your tetra meshing.
I have a simple (3D) geometry: a cylinder with a restriction in the middle.
And I would like to create the surface mesh but with 3 different sizes of cells: one big for the beginning, one very fine for the restriction and one between these two for the end.
I tried to use the part mesh setup but the problem is that the size of the maximum element must be a power of 2 so every size that I use must be at least the double of half the size as another one, which is not what I want.
Also I tried to compute the mesh part by part with changing the scale factor each time and it work well but there was no transitions between the 3 parts which made the mesh horrible...
Do you have any advice on this problem ? Am I trying to do this the wrong way ?
Thank you
Ben
Benzouz is offline   Reply With Quote
control tetra mesh part
FSI: Pressure and Normal Force don't match with expected values Geraud CFX 6 August 21, 2012 15:34
Hexa + Tetra meshing (Hybrid) in ICEM vmlxb6 ANSYS Meshing & Geometry 12 December 27, 2010 10:18
ICEM Tetra Meshing problme kambireddy ANSYS Meshing & Geometry 3 October 5, 2010 19:17
Hexa meshing or Tetra meshing??? NITIN DEWANGAN CFX 5 August 5, 2008 09:59
Tetra vs Hexa meshing for a wing Gilles Main CFD Forum 1 May 22, 2008 04:55
