[ANSYS Meshing] Crazy Surface Mesh
Old   December 2, 2015, 04:32
Default Crazy Surface Mesh
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
I have a problem with a part of my geometry that is imported from CAD.
I cutted the geometry in different bodies, one of them looks like a cylinder. For some reason, meshing doesn't recognize it as "sweepable", but that doesn't matter here, although this is suspicious and might be a hint to the solution. Anyway, the surface mesh of that body looks horrible and I have no idea how to get it better.
Here, have a look.
Do you have any idea what could be the reason for this?
This is "patch conforming", but I need it because I want to use pre-inflation. If I set it t "patch independent" the mesh looks fine.
I do not need to get it sweepable, because I want to have different edge resolutions on both sides.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   December 2, 2015, 05:15
Philipp
Ok, if I switch off "advanced sizing function" the mesh looks fine. But I need it at other parts...
Any other setting (on: fixed, on:curvature,...) leads to the bad mesh.
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 11:05
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
[snappyHexMesh] Problem with Sanpper, surface still Rough Zephiro88 OpenFOAM Meshing & Mesh Conversion 7 November 5, 2014 12:05
