[ANSYS Meshing] help!cannot use assembly mesh&multizone at the same time |
March 23, 2016, 01:41 |
Zeng Liyue
Rep Power: 11 |
Hi, everyone, I'm new to AnsysMeshing and have some problem with the assembly mesh.
I have several irregular sweepable bodies in a fluid domain, and I want to use multizone or sweep mesh method for these solid bodies; while the Cutcell assembly mesh for the huge fluid domain(which is a boolean intersected body). The problem is when i turned on the Cutcell assembly mesh method, the multizone mesh method become invalid.I can either use Cutcell for both the fluid domain and inner small solid bodies, or, use multizone for them. Though I tried defining virtual body for the fluid domain with surfaces, ANSYS Meshing always told me there's a leakage and meshing was not successful. Can I use Cutcell and multizone\sweep method at the same time for different bodies? Or how can I fix the leakage problem with the virtual body? .....Anyway the question is a bit long. Thanks for your time.... |
March 23, 2016, 07:01 |
Zeng Liyue
Rep Power: 11 |
thanks for the tip. actually I have tried cutting the domain just above these small bodies to make all the domain sweepable. But this will result in too many cells. So is there any way to cut down the number of cells if i use sweep method for all the bodies?
Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 09:08 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 02:20 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
mixerVesselAMI2D's mass is not balancing | sharonyue | OpenFOAM Running, Solving & CFD | 6 | June 10, 2013 09:34 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
