Unstructured Hybrid Mesh Density ICEM
Old   March 31, 2016, 14:43
Default Unstructured Hybrid Mesh Density ICEM
Matteo
fomalhaut is on a distinguished road
Hi, I need to use unstructured mesh in a portion of the Leading Edge of a compressor blade cascade. I used a free block, imposing only tetra inside. The problem is that close to the leading edge, the elements grow up, without keeping the height of the structured mesh (calculated to meet the y+ requirement).
Ho can I do to have a similar distribution to the structured mesh?
I enclose 2 snaps of the area.
fomalhaut is offline   Reply With Quote
Old   April 15, 2016, 19:06
Arrow
Jan
Jan Smedseng is on a distinguished road
Hallo.
In ICEM CFD, you cannot match tetra/prism with blockstructured mesh. Ok, you can do so, but then you cannot have a height over base of the complette layer more than 0.49 leading to very high volume change.
You can merge this grids in ANSYS Meshing, but why do you want to use a unstruct. mesh at you leading edge?
My experience is, that a C-Grid should be the best was of meshing this. But you have to handle the round leading edge.
Jan Smedseng is offline   Reply With Quote
[ANSYS Meshing] High quality unstructured hybrid mesh around ship flinde ANSYS Meshing & Geometry 2 March 3, 2015 18:04
[ICEM] Negative volume error in hybrid mesh siw ANSYS Meshing & Geometry 4 September 3, 2014 05:25
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre powpow CFX 3 December 20, 2012 09:14
about hybrid mesh in ICEM lian Main CFD Forum 1 February 27, 2008 11:01
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
