[ICEM] ICEM automatically merging two separte parts
Old   May 9, 2016, 08:48
Default ICEM automatically merging two separte parts
kasra
kazra is on a distinguished road
hi all
I have a model of an air to air heat exchanger. basically there are two air streams which are separated by a copper foil of 0.01mm thickness. when I mesh the geometry in ICEM the software automatically considers the copper foil to be part of the cold air stream. so because of this problem when I import the mesh into CFX it is not possible to specify boundaries for the copper sheet. any suggestion would be appreciated.
thanks in advance
kazra is offline   Reply With Quote
Old   May 15, 2016, 20:13
Steffen595 is on a distinguished road
in CFX you can set the boundary as thin material, then select copper and thickness. No idea, if that works in ICEM. Plus you would have to make 2 domains. And I found (in CFX), you have to set an expert parameter, so its 2 different physics, otherwise both fluids would mix.
Found that is an heat exchanger, there are 2 different fluids I dont want to mix.
Again, thats in CFX, not ICEM, but you may find something there. Separating domains was in Beta options.
Steffen595 is offline   Reply With Quote
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
ICEM mesh merging problem Serge CFX 2 October 22, 2007 06:13
merging edges in ICEM Virag Mishra CFX 4 August 24, 2007 06:06
Merging mesh elements in ICEM Felix CFX 1 May 9, 2007 10:33
ICEM CFD 5.1 Hex-Tet mesh merging failure bogesz CFX 1 January 29, 2005 06:46
