[GAMBIT] Scaling geometry with different factors by Gambit
Old   May 13, 2016, 10:19
Default Scaling geometry with different factors by Gambit
hewei is on a distinguished road
Does any one know how to scale multi-blocks in x-and y-direction using different scale factors? Basically the scale factor imposed on the block always the same.
Thanks!
wei
hewei is offline   Reply With Quote
Old   May 17, 2016, 02:21
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
do you want to scale your final mesh?
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   May 17, 2016, 03:38
Hello Maxime,
That's what I want, scale a sphere mesh into a prolate mesh.
would you like to share it?
Thanks!
Wei
Old   May 17, 2016, 04:05
-mAx-'s Avatar
Maxime Perelli
then you cannot.
In Gambit you can transform a geometry, but not the mesh (except translation / rotation)
Old   May 24, 2016, 04:05
then you cannot.
Thanks your reply. How about to control through the *dbs? I find some one said this can be achieved via external LOOP.
W
Old   May 24, 2016, 04:09
-mAx-'s Avatar
Maxime Perelli
once you mesh is done, you cannot "stretch it" (except in fluent with dynamic mesh).
If you want to transform it, you need to delete your mesh, adapt your geometry, then remesh
Old   May 24, 2016, 06:56
yes, that is what I want, delete the mesh firstly.
then adapt the geometry, I don't want to repeat the process, that is why trying to find the way to manipulate the geometry in Gambit, then re-mesh it.
is it possible? thanks,
W
Old   May 24, 2016, 07:14
-mAx-'s Avatar
Maxime Perelli
ah ok.
Then use the journal file (*.jou) and adapt it.
you may also use parameter
http://willem.engen.nl/uni/fluent/do...g_Journals.pdf
Old   May 24, 2016, 08:15
ah ok.
Thanks Maxime! I will learn it to see if it works.
w
Mesh geometry over airfoil with Gambit laith FLUENT 5 March 9, 2018 01:56
Geometry of Tank and Rushton Turbine in Gambit jawidnaik ANSYS Meshing & Geometry 1 February 4, 2015 07:28
What can I employ to create geometry besides Gambit? summer ANSYS Meshing & Geometry 2 February 11, 2011 14:50
3D geometry in gambit Meenu FLUENT 7 May 10, 2007 15:51
problem about Importing geometry in Gambit Hua Gu FLUENT 3 April 2, 2002 14:24
