May 13, 2016, 19:11 |
Problem when exporting face split
Dudu Cano
I have a cubic geometry with multiple face splits generated in the ansys modeler which will serve as velocity inputs for a Fluent simulation. I am quite new to ICEM, but I don't really know how to export those face splits to ICEM so that they are considered parts (and, thus, boundary conditions). I have tried to export the geometry and split the face already in ICEM, but it is giving me some trouble (bug?). Thanks a lot for your help Eduardo |
May 15, 2016, 04:28 |
Dudu Cano
Hello again,
I managed to solve the issue when importing the planes. Actually I believe it was a very simple question, my bad. I am now trying to mesh the domain I attach with ICEM. It is a room with multiple flow inlets (roof) and outlets (close to the floor) and obstacles in the domain. I am quite new to the blocking meshing strategy, I am trying to follow the next steps but I don't know if they are correct: 1. Generate parts for the inlets/outlets. 2. Block the whole geometry. 3. Split the block and remove the blocks associated to the obstacles. 4. Merge the blocks. 5. Split the block close to the inlets outlets so that a block is associated to each one. 6. Merge again the blocks so that there are not so many blocks. Is that a correct strategy? Thanks for your help, Eduardo Last edited by ecanop; May 15, 2016 at 13:37. |
icem, split, surface |
[blockMesh] Internal walls of zero thickness | anger | OpenFOAM Meshing & Mesh Conversion | 23 | February 6, 2020 18:25 |
[GAMBIT] Problem in link face mesh for periodic | newbie384 | ANSYS Meshing & Geometry | 1 | June 28, 2013 06:31 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
[Commercial meshers] Converting meshes that includes interfaces | ham | OpenFOAM Meshing & Mesh Conversion | 29 | January 8, 2007 08:58 |
